Attached FilesComment
Please Help ! ive got 3 T470s from my old company and every have supervisor lock, and a T450s with same problem.... but the 450s i dont save the original file ! thats a big problem i think.. for the first T470s ive got the Dump Bios Bin file here , i tried to make a patched file but its not working so please help... if i try to patch the original file the window open and close i tried with pyhton 3.8 and the latest with same Result
Hello everyone. I will need your help please. I tried everything to unlock my L560 but the patched bios file will not work for me. The patching process was successfull but I only get a black screen and no fan noise after writing the patched file. After I write back the original bios file everything works fine - but with my bios password set.
Can anyone try to patch my original bios file correctly that you can find attached?
Thanks a lot for your help!Attached FilesComment
Thanks a lot for your help!----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
write this file and follow steps described in autopatcher:
[ HOW TO USE THE PATCH ]
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory default
[ NOTES ]
When booting the patched BIOS you might have to:
- Hold the anti-tamper switch down the whole time (use tape)
- Remove the hard disk or replace it with a locked oneAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
[ NOTES ]
- Remove the hard disk or replace it with a locked oneComment
Last edited by volinakis; 08-12-2024, 03:15 PM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
let it run for 2 mins, it will restart few times with no image, just wait----------------------------------------------------------------------------------------------------------------------------------------------------------------------
It is so strange. It is not the first time that I managed to unlock a L560. Maybe my bios dump is corrupt? Or can it be something else?
Sorry for my late reply. I let it run for more than 10 minutes but the screen keeps black and no restart so far. I tried with power supply and also with battery.
It is so strange. It is not the first time that I managed to unlock a L560. Maybe my bios dump is corrupt? Or can it be something else?----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Thats right. But after I write back the original dump, the bios password is still there.
i dont know how to clean ME. Do you have a tutorial?
i will give it another try tomorrow.
Thank you, Everything worked perfectly as described. No issues. What a life saver!!
Lenovo T480s Bios Ver. 1.57 02/27/2024 Model 20L8S5T700 CPU I5 8250UComment
Hi guys i have an issue with autopatcher (trying to remove bios password on T450).tried with python 3.9, but i get no patched file eventhough it says it shoudl be done.
I m joinig the orginal bios here, can someone help? thx a million
https://www.badcaps.net/donateComment
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
- Loading...
