  • Markus1741
    • Sep 2020
    • 842
    • N/A
    #2421
    Originally posted by Alex_over
    When I flash the original bios, the laptop turns on
    Hello your two BIOS chips look very good not damaged nearby.
    I cleaned the ME region is the 8.4 MB file.
    Only the 4.2 MB can be patched with the Auto-Patcher.
    Much luck ...
    • Alex_over
      • Sep 2022
      • 16
      • Ukraine
      #2422
      Thanks friend, I will try to flash it
      • volinakis
        • Jan 2021
        • 2623
        • N/A
        #2423
        Originally posted by Syavko1
        Can someone remove the bios password
        try this file and follow steps described in #1
        [ HOW TO USE THE PATCH ]
        STEP 1: Flash and replace current BIOS with the generated patch file
        STEP 2: Boot the machine
        STEP 3: Press ENTER/F1/etc. to enter BIOS settings
        STEP 4: Enter any character when asked for Supervisor Password
        STEP 5: Press enter when it shows Hardware ID
        STEP 6: Press space bar 2x when asked
        STEP 7: Turn off machine
        STEP 8: Restore original BIOS
        STEP 9: Reset BIOS settings to factory default
        [ NOTES ]
        When booting the patched BIOS you might have to:
        - Hold the anti-tamper switch down the whole time (use tape)
        - Remove the hard disk or replace it with a locked one
        • volinakis
          • Jan 2021
          • 2623
          • N/A
          #2424
          Originally posted by buokhalid
          please help me to remove bios password
          MY laptop is lenovo E490 fe490/fe590/fe480 nm-b911
          rev: 2.0
          [ NOTES ]
          • ArcMak
            • Jul 2016
            • Brazil
            #2425
            Worked for me!
            Thank you Knucklegrumble, I just followed EXACTLY what you described and fixed my poor Lenovo P51.
            For the community reference I used a CH341A with NeoProgrammer 2.1.0.19, and a IC clamp (didn't remove the IC from the board as recommended in some articles).
            Mak
            • buokhalid
              • Sep 2022
              • 7
              • Philippine
              #2426
              [ NOTES ]
              Thanks for your efforts
              My laptop now is not posting at all
              Just power led with blank screen
              I don't know what happened
              Tried to reflash the bios the same result
              Even tried the original bios file which was created before it didn't work.
              Can the bios chip burned out?
              Is it possible?
              It is still accepting flash and the programmer still detecting the chip.
              Any idea or suggestions? Plz ….
              • volinakis
                • Jan 2021
                • 2623
                • N/A
                #2427
                Is it possible?
                Check if you didn't remove any component around bios chip by mistake while soldering/desoldering bios chip. Leave laptop on for a long time, from my experience it take between 1 to 2 mins to apply new settings from bios, you'll see keyboard leds flashing few times. I removed SVP from E490 with same method I created your patched bios, it should work.
                • buokhalid
                  • Sep 2022
                  • 7
                  • Philippine
                  #2428
                  I didn't desolder the chip
                  I used the clip with ch341a programmer.
                  I believe if the chip burned it will not accept programming or even the programmer detect the chip.
                  It is accepting the flash and verify it successfully with no issue.
                  Anyway i will check the area around the chip as you said. And will update you back.
                  Thanks bro
                  • Alex_over
                    • Sep 2022
                    • 16
                    • Ukraine
                    #2429
                    Much luck ...
                    I recorded the bios of the laptop, there is no image, and it beeps 5 times
                    • volinakis
                      • Jan 2021
                      • 2623
                      • N/A
                      #2430
                      I didn’t desolder the chip
                      Thanks bro
                      I had some troubles with Macronix chipsets, even programmer detected it and wrote it with no errors laptop didn't start. I replaced with Winbond and laptop started.
                      I see that your laptop can use both chipsets, try change it with W25Q128 if you have MX25L128
                      Also I gave up using clips because it can damage components placed near bios chipset and always desolder bios chipsets, there are some "pogo pins" i saw some users here use it and it's better than clips.
                      • buokhalid
                        • Sep 2022
                        • 7
                        • Philippine
                        #2431
                        [ NOTES ]
                        Appreciated
                        will try it after replacing the chip
                        • mregeling
                          • Mar 2023
                          • Netherlands
                          #2432
                          Hello, can someone help me remove the password of my Lenovo X270 ?
                          Thank you very much !
                          • Markus1741
                            • Sep 2020
                            • 842
                            • N/A
                            #2433
                            Hello try this patch ....
                            • Mettbroetchen
                              • Mar 2023
                              patcher works fine for me
                              T460s
                              Python 3.11
                              Programmer 341a mini black
                              Softw : CH341a Programmer 2.2.0.10
                              thanks to @Knucklegrumble
                              • kotlety
                                • Mar 2023
                                Hi, just wanted to say big thanks for the script and guide.
                                I succesfully managed to remove the Supervisor BIOS password on my T480.
                                For future reference, my machine is T480, type 20L6-SD8Q0M, June 2019, BIOS version 1.24.
                                Keep in mind you need to desolder the U49 chip (W25Q128JVS), it's located roughly between the RAM slot and where the discrete GPU would be. At first I made a mistake and desoldered U15 (near the CMOS battery) and was wondering why the patcher wouldn't work hehe.
                                I used RaspberryPi 4B and flashrom to read and write the binaries, but ran the patcher script on my Win 10 laptop.
                                Anyway, thanks again!
                                • olegi
                                  • Jun 2012
                                  • 63
                                  Hi everyone i have Lenovo x1 Yoga 20LE bios locked.Can someone help me remove the password.Regards
                                  • Markus1741
                                    • Sep 2020
                                    • 842
                                    • N/A
                                    #2437
                                    Try ...
                                    • olegi
                                      • Jun 2012
                                      • 63
                                      Thank you Markus1741. All OK
                                      • Othmane4you
                                        • Feb 2023
                                        • Morocco
                                        #2439
                                        Hi everyone
                                        i have a Thinkpad yoga 15 typ 20DQS00A00 with SVP
                                        Chip Winbond W25Q64FVS
                                        this is a verified backup i would like to patch it
                                        • Markus1741
                                          • Sep 2020
                                          • 842
                                          • N/A
                                          #2440
                                          Originally posted by Othmane4you
                                          Hi everyone
                                          Hello try it .....
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            by Bloodhoundje
                                            03-16-2024, 03:12 PM
