Hi guys is it possible to flash the eprom from a lenovo T470s using a CH341A?Comment
Finally tried this on my T440p, and it worked like a charm. Used a SOIC8 clip w/ a Raspberry Pi. Only issue now is to remove the logo the previous owner put at the boot screen, I should be safe to update the BIOS as well right?Comment
Good day, I kindly ask for help from the Lenovo T495 type 20NK pc forum, I dumped the Bios and through your program I generated the PATCHED bin, mounted the W25Q128FW eprom, I turn it on but I only get a black screen and a series of beeps, reinstalling the original bios leaves quietly. Now reading here on the forum I noticed that many complain about this problem, but it seemed to me that two people talking about the T495 have succeeded. Before making other attempts, I would like to understand if anyone has managed to get the PATCHED BIOS to work. Attached I put my original BIOS and the version produced by Tools. Thanks for any help on this.Last edited by SMDFlea; 03-26-2023, 12:32 PM.Comment
I'm really sorry for my stupid questions but i spent like 1 or 2 hours looking for an answer:
I managed to get a dump of my T570 bios.
I used autopatcher to get a patched version of it.
How the f*ck do I get it flashed back to the notebook?
I used Universal BIOS Backup Toolkit 2.0 to get the backup.
Which software do you recommend to flash the patched BIOS back to the notebook?
Thanks for your time - I really appriciate your help!Comment
Thanks for your time - I really appriciate your help!----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Hello. Does this method work with 11th generation intel i3?
I have a Lenovo V14 g3 IAP. There is a Bios password that I don't know.Comment
Getting an TL866II and solder off the chip is not worth the amount of money/time/risk for my purpose but kind of interesting topic!Comment
You can buy ch341a for this job, it's dirty cheap - a few bucks.----------------------------------------------------------------------------------------------------------------------------------------------------------
thanks, I've ordered it and will give it a try. As I've seen there is a kind of pliers I could connect to the chip without needing it to unsolder it. I'll let you know.
CheersComment
Hey guys, I need some help, it seems I made a dump of my bios using a W25Q128BV in my CH341A Programmer and I only noticed now that my chip is a W25Q128JVSQ... now I'm stuck in the 2 beeps of death... Is there something that can be done do salvage this?
Can someone please help me to patch this?Last edited by SMDFlea; 03-26-2023, 12:32 PM.Comment
Got my ThinkPad X250 supervisor password cleaned, thanks for the app!
I thought my X250 was bricked when I heard 5 beeps at power up(motherboard failure) after flashing the patched BIOS. But it turned out the beep code was 5 short beep [pause] 5 short beep. Which indicates TPM is refusing to power up the laptop, probably due to tampered BIOS.
I redone the patch from Ubuntu and the checksum result is identical to the one generated from Windows so a falsely patched BIOS is ruled out. I almost lost hope as TPM("Security Chip") cannot be deactivated and it was the discrete TPM1.2 instead of PTT. I also tried ME cleaner(+patch) but to no avail, the laptop power button just flashed once then powered off.
Fortunately physical presence for clearing was enabled and Secure Boot was not enabled. I flashed the original locked BIOS and cleared TPM from powershell with clear-tpm -useppi, in hope that the TPM won't complain about the tampered BIOS again.
I flashed the patched BIOS again, then the laptop booted! I just followed the instructions and everything worked as it should. The program did say "TPM certificated changed." before "Turn it off." message. I used a CH341a with a worned out SOIC clip, I had to hold my fingers on the clip all the time when the programming is in progress. At first I used AsProgrammed but it was a hit or miss in my case, then I used Flashrom GUI and all is well.
Your mileage may vary but that's how it worked for me. Hard labor and time consuming but the result is great, saved me $50+ for BIOS unlock service.Comment
Channel: BIOS Requests ONLY!
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by BloodhoundjeHi everyone,
I have desoldered the bios chip (GigaDevice...-
- Loading...
