hp 6050A2728501-MB-A01 bios
  • peste
    replied
    Re: hp 6050A2728501-MB-A01 bios
    Originally posted by KillMe3
    Hello everybody,
    i have a HP 850 G3 with bricked Bios
    is it possible to flash a new Bios with a programmer?
    The Chips are a WINBOND 25Q128FVPQ and 25Q64FVIQ
    do you need other Infomation?
    it is... post the full name and model and the original bios..
  • KillMe3
    replied
    Hello everybody,
  • Mazorca
    replied
    Post your old bios, it is needed to rebuild new one.
  • mbk.mbg
    replied
    i need bios work
    hp elitebook 840 g3
  • teknik62
    replied
    Re: hp bios
    Originally posted by lapfix
    Try and give Feedback
    thanks gave the image
  • hoaca388
    replied
    Originally posted by feri
    hello. I have a hp elitebook 850 g3 with amd discrete graphics. Motherboard is hp 6050a2728501-mb-a01. The issue is no display, fans are spinning. I got a hp 840 g3 uma bin file , its worked well just, no discrete graphics option.
    I have the original bin files , can anybody repair it for me?
  • feri
    replied
    Hello. I have a HP elitebook 850 G3 with AMD discrete graphics. Motherboard is hp 6050A2728501-MB-A01. The issue is no display, fans are spinning. I got a HP 840 G3 uma bin file , its worked well just, no discrete graphics option.
  • Dhaka Lab
    replied
    Please can you help me, I need BIOS + EC bin file for this model.
    HP 840 G3 6050A2728501-MB-A01 .
  • its service
    replied
    thnaks lapfix laptop working fine
  • lapfix
    replied
    i's another issue , be sure of your screen cable , see if there's any corrusion or something like that ...take measurements from lvds connector and post it here : https://www.badcaps.net/forum/forumdisplay.php?f=23
  • zmedia
    replied
    Re: hp bios
    is it white screen !!
    yes bro
  • zmedia
    replied
    Re: hp bios
    the basic problem as the ignition now a white screen after clean
  • lapfix
    replied
    Re: hp bios
  • zmedia
    replied
    Re: hp bios
    try and give feedback
    no display
  • peste
    replied
    Re: hp bios
    Originally posted by zmedia
    Orginal bios if you can clear this thank you
    try..
  • lapfix
    replied
    Re: hp bios
  • zmedia
    replied
    Re: hp bios
  • peste
    replied
    Re: hp bios
    what is written on the case, not on the motherboard, and the original bios ..the model on the case..
  • zmedia
    replied
    Re: hp bios
    look
  • zmedia
    replied
    Re: hp bios
    i dont have full name i have juste model for motherboard
  • Habble7
    by Habble7
    Suspected Cause:
    Troubleshooting Attempts:
    05-22-2025, 07:28 AM
  • DynaxSC
    by DynaxSC
    11-17-2023, 10:56 AM
  • grimacelord
    Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
    by grimacelord
    This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
    Motherboard model number: DA0PAMB46A1 REV: A
    Secondary motherboard model number: 0PAB
    SKU: 685K4UA
    Serial number is: 5CD3223BJP
    Recently reflashed this laptop with latest BIOS and once...
    05-07-2024, 08:06 AM
  • DynaxSC
    Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
    by DynaxSC
    I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
    It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
    I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
    11-06-2022, 05:22 PM
  • TacticalFahrrad
    [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
    by TacticalFahrrad
    I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
    BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
    I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
    Yesterday, 04:09 AM
