Nee bios lenovo yoga 310-11iap
  • PURNAMA
    • May 2020
    • 64
    • jakarta
    CODE:BM5594_VER 1.4
  • basic
    • Oct 2017
    • 229
    • 86357289244
    Re: Nee bios lenovo yoga 310-11iap
    try this..
    • PURNAMA
      • May 2020
      • 64
      • jakarta
      Thx,i will tell you the result
      • PURNAMA
        • May 2020
        • 64
        • jakarta
        not working
        • lapfix
          • Mar 2020
          • 2742
          • my workshop
          Originally posted by PURNAMA
          not working
          Post your old dump
          • PURNAMA
            • May 2020
            • 64
            • jakarta
            this backup dump file
            • peste
              • Dec 2016
              • 12945
              • ROMANIA
              Try..bios extracted from the update on the Lenovo website ..
              DMI+WINKEY 383000-38503F
              • PURNAMA
                • May 2020
                • 64
                • jakarta
                thx..work for me
                • Pascal Komlassan
                  • Jan 2017
                  • 809
                  • TOGO
                  Hello plaese i need the password for 6440DF
                  this is my backup thanks
                  • ammi
                    • Mar 2017
                    • 32
                    • indonesia
                    hi...plaese clearMe my dump bios
                    • Doniciputat
                      • Aug 2022
                      • 110
                      • Indonesia
                      thanks master
                      • mohamed nafees
                        • Feb 2023
                        • 5
                        • Sri Lanka
                        ​pls help me ineed bios file for this and i try to take buckup my chip is currupted so i need to replace that so i have new chip but i dont have file and i tried all file here but when i connect battery power light turned on contuies turn on pls help me
                        advance thanks.....
                      • ZERO_1090
                        • May 2020
                        • Mexico
                        try this..
                        Tanks it works for me too
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • Wahaz
                          by Wahaz
                          10-30-2023, 08:42 PM
                        • HotSaladMan
                          Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
                          by HotSaladMan
                          *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
                          Model : Lenovo ThinkBook 14S Yoga ITL
                          S/N : MP28JT19
                          MFG Date : 2022/02/09
                          Factory ID PRC4
                          MO : MPNXB26080FX
                          MTM : 20WE001US
                          MODULE FCC ID : PD9AX201NG
                          IC : 1000M-AX201NG
                          BOARD INFO
                          FLV34 LA-KO51P
                          REV : 1B 2020-08-24
                          Bit of Info
                          Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
                          chip id, so i would always uncheck the id check, so it would bypass the error
                          i did in fact make...
                          11-07-2024, 07:46 AM
                        • beogeek
                          Lenovo Yoga Slim 7 14APU8 Bios Request
                          by beogeek
                          I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
                          Attached is the bios dump in the state I received it...
                          10-24-2024, 12:54 PM
                        • grimacelord
                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                          by grimacelord
                          Hello there.
                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                          History:
                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                          I searched for this error online and discovered...
                          03-15-2023, 03:29 PM
