HP Fpw50 la-h321p rev 1.0
  • redpro
    • Dec 2022
    • Argentina
    Re: HP Fpw50 la-h325p rev 1.0
    Originally posted by peste
    post the full name and model of the laptop and the original bios of the laptop
    HP Fpw50 la-h325p rev 1.0 attached my bios corrupted with black screen.
    • peste
      • Dec 2016
      • 12262
      • ROMANIA
      Originally posted by redpro
      HP Fpw50 la-h325p rev 1.0 adjunto mi bios corrupta con pantalla negra.
      in English please....and post the original bios even if it is corrupted..
      • mtechtop
        • Oct 2020
        • 3
        • gabon
        Re: HP Fpw50 la-h321p rev 1.0
        hello everyone plz can i have a working HP Fpw50 la-h325p rev 1.0 bios
        • peste
          • Dec 2016
          • 12262
          • ROMANIA
          read this..
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • Mephysis
            DUMP DVR HIKVISION DS-7208HGHI-K1 (80389 Rev 1.3 Firmware)
            by Mephysis
            Hello guys i really need help, i recently updated my DS-7208HGHI-K1 and it somehow got bricked, I've got it up and working now by flashing a new dump file i found but the serial number is really wrong and the uploader of the dump file probably intentionally did it.
            I still have the bricked dump file is it possible to transfer the serial number of the "bricked dump" to the "working dump"?
            03-27-2025, 02:34 AM
          • Andreas_de
            Power supply Manson NTP-5561 (5661) LCD controller dead - PIC18F87K90 HEX dump required
            by Andreas_de
            Hello!
            i got a damaged Manson NTP-5561 (60V, 1,6A DC output) and and the main issue is that the controler IC for the LCD display has a short. The controler IC PIC18F87K90 is mounted on the back of the back of the LCD. Vss-Vdd = 3 Ohm. The 5V and 3,3V power line was killed as well, but that is not a problem. A new LDO 3,3V and 5V 7805 is already ordered.
            Replacing the PIC18F87K90 is necessary but that makes no sense without having the HEX dump of the new controler.
            Does anybody have such a power supply and could do a HEX dump of the Flash and EEPROM memory?
            04-12-2025, 10:38 AM
          • re-atari
            Anycubic Photon 5.5 3D printer 25Q32 flashrom dump needed
            by re-atari
            Hello all, as the title says, I'm very much in need of a valid firmware dump of a Anycubic Photon 5.5 3D resin printer. It's stored in a Winbond 25Q32, so it's 4Mbyte.
            Here's a little background for my request. A few weeks ago I bought this 3D printer from a guy who had moved on to a PLA printer. I got it at a vey reasonable price, as it was in a defective state. The seller told me that he had experienced a power failure during a firmware upgrade, after which the printer appeared to be dead. He thought the firmware was corrupted in such a way that the printer was now bricked. As he...
            02-03-2025, 06:49 PM
          • Buzzfuzz2k
            Bios password removal on a Unowhy dump
            by Buzzfuzz2k
            Hi Everyone,
            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
            the Computer is a Unowhy small pc
            N° UYM6524702229
            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
            My first attempt was to get the bios dump from windows...
            11-13-2023, 07:37 AM
