asus X551C BIOS
  • kadi144
    • Aug 2015
    • 690
    • algerie
    asus X551C BIOS
    hello !!!!
    i have try to flash by one
    but d"ont flash it and i have changed the ic but the same
    the mather is x551ca rev 2.2
    i need a working bios please
    merci
  • kadi144
    • Aug 2015
    • 690
    • algerie
    Re: asus X551C BIOS
    x551ca rev 2 2-20180104T191739Z-001
    this bios no accept flashing
    • peste
      • Dec 2016
      • 12365
      • ROMANIA
      Re: asus X551C BIOS
      try..
      • spurki
        • Apr 2020
        • 43
        • romania
        Re: asus X551C BIOS
        Originally posted by peste
        try..
        It is a working bios ,thanks!
        • tano2060
          • May 2018
          • 27
          • Macedonia
          Re: asus X551C BIOS
          try..
          Nice. Thanks.
          • GREAT_MERA
            • Jul 2021
            • 14
            • sri lanka
            any one got ec bin for x551ca rev 2.2 ..
            • shiyab
              • Sep 2023
              • 1252
              • india
              post snid and main bios
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • throwaway327
                by throwaway327
                Model No: RC72LA
                Serial No: SBNVKD001014459
                06-18-2025, 05:52 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • lrouw84
                by lrouw84
                Hi there,
                01-28-2023, 01:31 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
