macbook pro a1708
  • laptopcenter
    • Mar 2019
    • 90
    • haifa
    macbook pro a1708
    Hi
    I have problem with macbook pro a1708 it turn on and restart with no display please every body can correct this whit old bios >>>
  • peste
    • Dec 2016
    • 13421
    • ROMANIA
    Re: macbook pro a1708
    try..
    • laptopcenter
      • Mar 2019
      • 90
      • haifa
      Originally posted by peste
      try..
      First thanks for quick help but the file ok change the stat of my mother and cpu hotting with stay on but no view you can help me
      thanks again
      • laptopcenter
        • Mar 2019
        • 90
        • haifa
        • peste
          • Dec 2016
          • 13421
          • ROMANIA
          Originally posted by laptopcenter
          try..
          • Eleways
            • Oct 2014
            • 62
            • Italy
            Macbook pro A1708 - replace bios
            Hi there.
            I've bought some motherboard A1708 with replaced bios. These motherboards doesn't works, or works very slow.
            I need to fix these, but i don't know how. I've tried to ask here about a good Bios, but no one works.
            Can you tell me the way to modify the bios as to work on this board? I don't have the original bios and i don't have the serial number of the board.
            Many thanks for your help
            luke
            • peste
              • Dec 2016
              • 13421
              • ROMANIA
              Re: Macbook pro A1708 - replace bios
              Originally posted by Eleways
              Hi there.
              luke
              the motherboard model is written on the motherboard, do you still have the old motherboard? are they identical? post the full name and model of the EMC laptop, serial number S/N on the case, the motherboard model (the new one) and the original bios from the old board...
              • EpicFix
                MacBook Pro A1708 820-00840 stuck @ 5V, no power, no charging
                by EpicFix
                Hey guys, I need a little help here. I have a MacBook Pro A1708 820-00840 stuck @ 5V. Started off affecting just one port but now it's affecting both. Both CD3215 ics were replaced but the issue remains. One port does a loop and the other stays at a constant 5V. Both CD3215 have 3V incoming. I checked for PP3V3_G3H @ R3000, C3100 and C3108, R3001, C3200 and C3208. The weird thing is though that the ammeter shows the current draw (5V @ 0.5A) coming out from the port as opposed to it going in. Any ideas on helping me fix this?
                04-08-2025, 09:55 AM
              • 24gsm
                MacBook Pro A1708 install macos fail
                by 24gsm
                hi to all
                i have MacBook Pro (13-inch, 2017, Two Thunderbolt 3 ports)
                after enter to recovery and format hdd 1to .
                after try to install macos online . its frezz at loading install in boot and i waiting few hour but nothing i ty install by boot using flash disk but same issu
                can help please
                Serial Number: FVFXP0U0HV2J
                Config Code: HV2J
                Find My Mac: OFF
                04-16-2025, 03:57 AM
              • envym
                MacBook Pro 2018 with Activation Lock
                by envym
                Hi everyone!
                I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                06-27-2025, 08:54 AM
              • obelix24
                MacBook Pro a2442 - 20v restart every second
                by obelix24
                I just got one MacBook Pro a2442 (M1 Pro) there was small liquid damage.
                Board starts normally at 5V and then jumps to 20V but after few seconds USB-C meter restarts (on every port) - sometime 1 or 2 times it's start and doesn't restart.
                There was hotspot on U5200 (but it looks like on PIN1 (CHGR_GATE_Q4) but I've check in diode mode and it was ok reading (but I've replaced it anyway but still the same ...
                There was corrosion around UR660, UR630, UR600 but I've checked all CAPS and it looks ok ...
                When I connect USB-C meter and check with...
                11-07-2024, 11:34 AM
              • AlexVG
                Macbook A1708 820-00840 not a start
                by AlexVG
                Hi everybody
                I have Macbook A1708 820-00840
                It goes through all steps to start
                exclude last steps power PPVCCCPU_S0G and PPVCCGT_S0G
                Besides, no exchange on
                CPU_VIDSCLK
                CPU_VIDSOUT
                However CPU_PWRGD is OK
                CPU_PROCHOT is down.
                I replaced SPI dump from here:
                https://www.badcaps.net/forum/troubl...n-me-pram-bios
                Unfortunately did't help me.
                Would...
                11-07-2024, 09:05 AM
