Panasonic CF-20 Bios Password
Re: Panasonic CF-20 Bios Password
lol, I posted in the wrong thread, sorry!----------------------------------------------------------------------------------------------------------------------------------------------------------------------
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Hi my friends,
I have two same Panasonic CF-20E (mk2) asking password at boot.
- I unlocked the first one replacing by "0" in one of the 4 dump areas, it was a success.
- For the seconde one, it's not working. Booting OK but asking password. Even, deleting password_areas + ME_clean is not working, keep asking for password.
Can the password be stored in EC ?
Attached FilesComment
Read the rules before posting:
https://www.badcaps.net/forum/troubl...sting?t=103570
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Edit: Added extracted EC and edited EC.Comment
work but only with no screen (hdm ior lcd panel same)
it's not bios problem
https://www.badcaps.net/forum/troubl...20#post3223669
Hi my friends,
Can the password be stored in EC ?----------------------------------------------------------------------------------------------------------------------------------------------------------------------
could anyone help please remove bios password?
LOCKED BIOS
model cf-20G5184VM
sn 8DKKA78193Attached FilesComment
Attached Files↵
https://www.badcaps.net/donateComment
You need to check your process again,↵
try this oneAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Need help... BIOS is not locked, system starts and perfectly works from USB but device hangs during POST if any SSD presents in its M.2 slot inside the case instead of connecting via USB3 and USB-M2 adapter as I have to work for now.
This issue has appeared after macOS update (yes, a third system on it is Hackintosh).
First time I've got this problem after same action - the seller simply changed a whole device by warranty. I've thought it was a hardware problem with SATA controller. So now I think that system updater rewrote some UEFI areas - CMOS battery removing didn't help. BIOS update program fails with unknown error (code 999 IIRC).
Panasonic CF-20mk2
Model CF-20G5-05VM as printed on label (or CF-20G5108VM / CF-VEK206LM as shown in BIOS setup)
Serial 9FKKC22343 as printed (2nd serial in BIOS setup after slash is 9FKKC22328)Comment
by longmt1990Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
Please help me remove bios password.
Thank you so much-
Channel: BIOS Requests ONLY!
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by wishes2022can you please remove password of CF-SR4 or extract .exe file?...
- Loading...
