Panasonic CF-20 Bios Password
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1312
    • France
    Re: Panasonic CF-20 Bios Password
    Originally posted by volinakis
    for beep codes I use an app on my phone named Lenovo PC Diagnostic. try it, maybe you figure out what hardware problem is.
    a single beep when forcing the shutdown, I think Lenovo Diag will not help me on this one.
    It makes the same beep with a functional tablet
    • volinakis
      • Jan 2021
      • 2871
      • N/A
      lol, I posted in the wrong thread, sorry!
      • WebK
        • Dec 2021
        • 9
        • France
        Hi my friends,
        I have two same Panasonic CF-20E (mk2) asking password at boot.
        - I unlocked the first one replacing by "0" in one of the 4 dump areas, it was a success.
        - For the seconde one, it's not working. Booting OK but asking password. Even, deleting password_areas + ME_clean is not working, keep asking for password.
        Can the password be stored in EC ?
        • Vesko356
          Vesko356 commented
          Editing a comment
          Read the rules before posting:
          https://www.badcaps.net/forum/troubl...sting?t=103570
          You MUST:
          • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
      • WebK
        • Dec 2021
        • 9
        • France
        MODEL NO: CF-20E0205TF
        SERIAL NO: 9BKCC08093
        For motherboard information, i need to disassemble again .
          • 21584
          Need help bios for Cf20
          blackscreen, no boot, no backlight after save and exit in bios setup.
          just led power on/off react
          Serial in dump
          I have tried several bios here, none have worked so far
          thanks
          Bios with latest update + ME firmware.
          Edit: Added extracted EC and edited EC.
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1312
            • France
            #26
            work but only with no screen (hdm ior lcd panel same)
            it's not bios problem
            https://www.badcaps.net/forum/troubl...20#post3223669
            • volinakis
              • Jan 2021
              • 2871
              • N/A
              #27
              Originally posted by WebK
              Hi my friends,
              try this one
              • nstnkt
                • Apr 2012
                • italy
                #28
                IF this is for unlocking TRY this...
                thank you this had worked on 2022 version!
                • WebK
                  • Dec 2021
                  • 9
                  • France
                  #29
                  try this one
                  Thank you very much, my friend.
                  I solved the problem using the first one CF-20 cleaned dump. i did a copy past of second one information areas and all was OK.
                  Really appreciate your help.
                  • aLEXSTARLING
                    • Jul 2020
                    • 60
                    • Ukraine
                    #30
                    could anyone help please remove bios password?
                    LOCKED BIOS
                    model cf-20G5184VM
                    sn 8DKKA78193
                  • hoaca388
                    Badcaps
                    • Jan 2022
                    • 12237
                    #31
                    LOCKED BIOS
                    model cf-20G5184VM
                    sn 8DKKA78193
                    Removed
                    • aLEXSTARLING
                      • Jul 2020
                      • 60
                      • Ukraine
                      #32
                      not working
                      • aLEXSTARLING
                        • Jul 2020
                        • 60
                        • Ukraine
                        #33
                        Originally posted by hoaca388
                        Removed
                        After removing the password, the laptop does not turn on
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12237
                          #34
                          You need to check your process again,
                          • aLEXSTARLING
                            • Jul 2020
                            • 60
                            • Ukraine
                            #35
                            original file works
                            • aLEXSTARLING
                              • Jul 2020
                              • 60
                              • Ukraine
                              #36
                              Are there any other options?
                              • volinakis
                                • Jan 2021
                                • 2871
                                • N/A
                                #37
                                try this one
                                • aLEXSTARLING
                                  • Jul 2020
                                  • 60
                                  • Ukraine
                                  #38
                                  it works, you are a legend
                                  • moh1994
                                    • Sep 2023
                                    • 7
                                    • Türkiye
                                    #39
                                    qayyum786 ​ thanks okey 100 1000
                                    • Anzo Matrix
                                      • Jun 2024
                                      • 4
                                      • not Florida
                                      #40
                                      Need help... BIOS is not locked, system starts and perfectly works from USB but device hangs during POST if any SSD presents in its M.2 slot inside the case instead of connecting via USB3 and USB-M2 adapter as I have to work for now.
                                      This issue has appeared after macOS update (yes, a third system on it is Hackintosh).
                                      First time I've got this problem after same action - the seller simply changed a whole device by warranty. I've thought it was a hardware problem with SATA controller. So now I think that system updater rewrote some UEFI areas - CMOS battery removing didn't help. BIOS update program fails with unknown error (code 999 IIRC).
                                      Panasonic CF-20mk2
                                      Model CF-20G5-05VM as printed on label (or CF-20G5108VM / CF-VEK206LM as shown in BIOS setup)
                                      Serial 9FKKC22343 as printed (2nd serial in BIOS setup after slash is 9FKKC22328)
