Asus X441UBR Rev 2.1
  • servis jaya.comp
    • Oct 2014
    • 33
    • Indonesia
    Hi All Master...I Need Bios Asus X441UBR Rev 2.1
    Please Share ..Thanks...
    this is BackUp Bios
  • Claudiomfa
    • Nov 2015
    • 455
    • Portugal
    Re: Asus X441UBR Rev 2.1
    try and report
    • go to fix
      • Dec 2020
      • 6
      • INDONESIA
      Thank You so much. This bios Working 100%. but late on Display. It takes 5-7 seconds to display on the screen after the laptop is turned on.
      • ryan yanuar
        • Jul 2023
        • Indonesia
        this is BackUp Bios
        Thank you so much,... I try hope it works...
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • grimacelord
          by grimacelord
          07-10-2025, 02:52 PM
        • ngngocson113
          I need bios asus tp301u ( uma ( vga share))
          by ngngocson113
          hi everyone
          i need bios asus tp301uj ( "uma " vga share)
          my mainboard doesn't use vga chip and it uses vga together with cpu.
          I used some bios files (good).of the mainboard that uses vga chip. but can not turn on power.Meanwhile,its original bios file can turn on power But nothing on the screen
          thanks everyone....
          09-25-2025, 02:20 AM
        • lrouw84
          by lrouw84
          Hi there,
          01-28-2023, 01:31 PM
        • ferah831208
          help with bios decompose for Asus s5506ma
          by ferah831208
          I have an Asus s5506ma that was bricked after a Windows update supposedly when it was updating bios. It seems to be a meteorlake Intel CPU core ultra, I cannot find too much info regarding this hardware, anyone have info about if it contains Intel ME engine and if there is any tool for disassemble spi image like we do with all CSME or TXE versions using the appropriate Intel ME tool? The problem is original bios file Asus provides, has bios guard protection, I downloaded the latest update for Ami_pfat_extractor from plomatov (previous versions of AMI bios guard extractor doesn't work),with that...
          08-24-2025, 05:35 PM
