hedwig-6050a2993001-mb-a03 do have bios
  • platinumsteel
    • May 2019
    • 234
    • Trinidad&Tobago
    HP 14-cf009ca Bios needed
    hi gooday.I have a HEDWIG-6050A2993001-MB-A03 it was doing an update and the customer shut it off. I can't go into the bios it says something about bios error.Can u all please repair it thanks .I have provided the original backup.
    • peste
      • Dec 2016
      • 12226
      • ROMANIA
      Re: HP 14-cf009ca Bios needed
      bios extracted from the HP site update
      DMI 3C7000 - 3C8FFF
      KEYWIN 3C5000 - 3C503F
      • platinumsteel
        • May 2019
        • 234
        • Trinidad&Tobago
        Okay thanks again my friend . Long time no see. Bios working 100% i get picture now.
        • chumatez
          • Jan 2021
          • 18
          • Nigeria
          Re: HP bios HEDWIG-6050A2993001-MB-A03(A3)
          Originally posted by piszpunta
          extract official hp site.
          Your bid 0849e
          thanks very much, it works for me
          • tsok
            • Feb 2019
            • 14
            • philippines
            Re: hedwig-6050a2993001-mb-a03 do have bios
            capslock blink 3 times. no display is this bios issue?
            somebody can fix this heres my backup bios thank you much..
            • hardware1
              • Sep 2021
              • 2887
              • N/A
              #26
              I think 3 times is referring to RAM issue. Try another good RAM, check the Pins of your RAM slot and your RAM Voltage.
              After that we can assume a BIOS Issue, but we will need your Device Model and Serial Number.
              all donations are welcome,
              • tsok
                • Feb 2019
                • 14
                • philippines
                #27
                yes sir ram supply good all coil are present ..tried 4 good ram still blink 3 times..
                heres my model number:14s-cf0121tu
                SN#5CG935583H
                thank you sir
                • hardware1
                  • Sep 2021
                  • 2887
                  • N/A
                  #28
                  SN#5CG935583H
                  thank you sir
                  Here's your New BIOS, it's a Virgin BIOS from HP with your DMI and Windows Key.
                  • tsok
                    • Feb 2019
                    • 14
                    • philippines
                    #29
                    thank you ..after trying this bios still no display blink code change to 3 long and 2 short
                    • peste
                      • Dec 2016
                      • 12226
                      • ROMANIA
                      #30
                      at post #22 you have the bios extracted from the website ... you won't find a better one ... you just have to write it correctly ... if it doesn't work, you have another problem ...
                      • tsok
                        • Feb 2019
                        • 14
                        • philippines
                        #31
                        after flashing good bin ..i think its good bin no blinking..but still no display, ram not getting power, current draw from dc bench is 0.110a with ram or without..
                        1.2v,1.8v and 5v is present .processor is normal temp .i dont have schematic or brd ..thank you sir
                        • kalilinux25
                          • Mar 2018
                          • 2069
                          • ZAMBOANGA SIBUGAY
                          #32
                          Tried external display? to confirm?
                          • tsok
                            • Feb 2019
                            • 14
                            • philippines
                            #33
                            I've tried sir but still no display using hdmi
                            • kalilinux25
                              • Mar 2018
                              • 2069
                              • ZAMBOANGA SIBUGAY
                              #34
                              better check all the chip, espicially the vram section chip, need to search all chip on google and record all reading and post it to the other thread not here
                              • tsok
                                • Feb 2019
                                • 14
                                • philippines
                                #35
                                ok sir i will .. thanks much
                                • kalilinux25
                                  • Mar 2018
                                  • 2069
                                  • ZAMBOANGA SIBUGAY
                                  #36
                                  post your problem Ill gladdly assist if I can
                                  • tsok
                                    • Feb 2019
                                    • 14
                                    • philippines
                                    #37
                                    1st status is blinking capslock ..after flashing good bin no blinking but still no display current draw is 0.110a with or without ram ..cpu is in normal temp. voltage coil check near ram i got 1.2v,1.8 and 5v is present ..voltage check in ram capacitor i got 1.2 and 5v.. i dont have schematic or brv.. thank sir
                                      • 20279
                                      Post for hardware help in the main laptop forum --> https://www.badcaps.net/forum/newthr...newthread&f=23
                                      • vienzen
                                        • Feb 2015
                                        • 112
                                        • PHILIPPINES
                                        #39
                                        help no display problem
                                        hedwig-6050a2993001-mb-a03 (a3)
                                        14-NAR-GLK
                                        TPN-1130
                                        BIOS backup
                                        • peste
                                          • Dec 2016
                                          • 12226
                                          • ROMANIA
                                          #40
                                          14-NAR-GLK
                                          TPN-1130
                                          BIOS backup
                                          you have everything you need at post#22
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • Bloodhoundje
                                            HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
                                            by Bloodhoundje
                                            I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
                                            I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
                                            After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
                                            I have desoldered the bios chip (GigaDevice...
                                            03-16-2024, 03:12 PM
                                          • nosfay
                                            Intel NUC NUC10i5FNK - Bios & firmware request
                                            by nosfay
                                            I need clean bios & firmware for an intel that doesn't boot.
                                            Model : NUC10FNK
                                            Product code : BXNUC10i5FNKN2
                                            Here is my dump, but i dont know which one is the bios or firmware as there is 2 different chip, MX25L25673G and MX25V8035F so I've dumped both.
                                            Thanks for your help !
                                            EDIT: you can find official bios and firmware here https://www.asus.com/supportonly/nuc...helpdesk_bios/...
                                            11-01-2024, 08:10 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
