Intel NUC NUC10i5FNK - Bios & firmware request
  • nosfay
    • May 2024
    • 64
    • France
    I need clean bios & firmware for an intel that doesn't boot.
    Model : NUC10FNK
    Product code : BXNUC10i5FNKN2
    Here is my dump, but i dont know which one is the bios or firmware as there is 2 different chip, MX25L25673G and MX25V8035F so I've dumped both.
    Thanks for your help !
    EDIT: you can find official bios and firmware here https://www.asus.com/supportonly/nuc...helpdesk_bios/
  • SoporteNetFe
    • Aug 2021
    • 121
    • Argentina
    You try with bios from asus? You bios version its 0058, use 0065 ( FN0065.bin ) from:
    https://dlcdnets.asus.com/pub/ASUS/N...del=NUC10I5FNK
    32mb its a BIOS.
    • nosfay
      • May 2024
      • 64
      • France
      Do I need to transfer ME region from DUMP ? I cannot do a regular bios update, the nuc is acting realling weird
      • nosfay
        • May 2024
        • 64
        • France
        I've fllashed bios directly from asus website (FN0065.bin), but it doesnt boot, sometimes I've got a sterady blue led, sometimes it loop boot every 4s.
        • nosfay
          • May 2024
          • 64
          • France
          Does anyone can help to have a clean bios with ME region from dump please?
          I've forgot to link SN : GEFN308005SJ
          • nosfay
            • May 2024
            • 64
            • France
            Up, if anyone can help please
            • peste
              • 13809
              • ROMANIA
              post the contents of the bios chip even if it is corrupted..full name and model, motherboard model,etc..maybe someone can help you..
              • cr4zychriss
                by cr4zychriss
                • Rebrand: PC Specialist
                11-14-2025, 04:04 PM
              • Wahaz
                by Wahaz
                10-30-2023, 08:42 PM
              • hotcrossedbuns999
                M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                by hotcrossedbuns999
                My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                3. I could only locate two chips that look like bios chips. Could someone verify this
                01-03-2025, 12:32 PM
              • GardevoirForEver
                Embedded Controller issues, living an absolute H*LL with my ASUS Vivobook Pro 16X OLED
                by GardevoirForEver
                I've been dealing with so many complications for months, trying to find and then fix the root cause of the issue I really need help and I have to solve this on my own (Going to Asus headquarters isn't an option for me. First, because I'm very stubborn and want to insist that I can fix this sort-of-myself somehow, and second, the location is too far away for me anyway).
                Right now I'm desperate trying to put an end to this nightmare, but OK, I'll do my best to be somewhat brief in explaining and relating the entire situation and context.
                The motherboard of my ASUS...
                11-15-2025, 04:30 PM
              • chunter2
                HP ENVY 15-j030eb BIOS/firmware request
                by chunter2
                I've got an HP ENVY 15 Model 15-j030eb that I had originally flashed with the wrong BIOS. I was able to get a CH341a and flash it back but in the process accidentally erased the wrong chip. So, I'm looking for the firmware/BIOS for the Pm25LD512 chip which I think relates to the power management since it's right beside an IT8527E chip.
                06-04-2025, 04:04 AM
