Help please lenovo z40 70
  • aldopc
    • Jul 2017
    • 484
    • Chilito
    Hello friends, I have this Lenovo Z40 70 without display, I found a bios here and it works but it does not recognize wireless cards, it only recognizes bluetooth, but I have already fitted several cards and do not recognize any, can it be a problem with the bios or can it be damaged before? Attached original file without display and file that boots and found on this site.
  • peste
    • Dec 2016
    • 13924
    • ROMANIA
    Re: Help please lenovo z40 70
    you posted two bios of different lengths, remove the bios chip from the motherboard before writing or reading. I posted two bios, one extras from the Lenovo website and another Clean Me to your original. I hope it helps.
      • 22276
      The bios has a "Whitelist" ,it will only use certain lenovo wireless cards,you can`t use any card you want unless the bios is modified.See this thread on bios-mods -
      https://www.bios-mods.com/forum/Thre...emoval?page=63
      • aldopc
        • Jul 2017
        • 484
        • Chilito
        If friend Plague the file I read it outside the motherboard and it is 16mb I also know that the 8mb that this here worked but without wifi ... I will do the test with your files very grateful, I will comment on the result later thanks.
        • aldopc
          • Jul 2017
          • 484
          • Chilito
          If it happened in older models, but in this case when starting the computer it is not sending a message from an unsupported wireless card ... enter the operating system without error warnings, I will try the Plague files and comment thanks for your help Smdflea.
          • aldopc
            • Jul 2017
            • 484
            • Chilito
            Hello probe the two files both start but the problem only appears the bluetooth in the device manager, install a new operating system, but the wifi card still does not work, this card is the original from the team and I have tried it on another laptop and It works correctly, I saw the option that indicates Smdflea but I am not very expert to edit the bios and delete the whitelist .... can someone do it for me please
              • 22276
              https://forums.lenovo.com/t5/Lenovo-...page=1#1775251
              • fire1234
                • Dec 2017
                • 77
                • Poland
                Bios Whitelist Remove
                • aldopc
                  • Jul 2017
                  • 484
                  • Chilito
                  If friend I installed the power manager but the problem continues, I also tried the fire1234 file without whitelist, I was wrong to specify the model of the equipment is a G40-70 but the files you used are all from g40-70 I have doubts with the first dump since it is 16mb the original dump, all the others you tried are 8mb and none of them recognize the serial number or the name of the product, do you think that is the problem?
                  • aldopc
                    • Jul 2017
                    • 484
                    • Chilito
                    Thanks fire1234, for your work but the problem continues .... I was wrong to specify the model of the equipment is a G40-70 but the files you used are all from g40-70 I have doubts with the first dump since the dump is 16mb original, all the others you tried are 8mb and none of them recognize the serial number or the name of the product, do you think that is the problem?
                    • fire1234
                      • Dec 2017
                      • 77
                      • Poland
                      Bios to G40-70, white list disabled, serial numbers and windows key copied. The bios should have 8mb, I have never met in this model that the bios had 16mb.
                      • aldopc
                        • Jul 2017
                        • 484
                        • Chilito
                        516/5000
                        Ok, friend, thank you very much, I appreciate your help, I have tried your file, but the wifi problem persists now if the serial numbers and the product name appear, but apparently it is a problem on the motherboard, regarding the biography of 16mb I already found what is the problem, I did a reading in the programmer software without selecting the correct chip, and I take a chip of different size and that's why a 16mb file was created you are correct this bios is 8mbn chip, Again, thank you very much.
                        • lucaszmn
                          by lucaszmn
                          Problem:
                          Initial Findings:
                          • I concluded that the
                          08-12-2025, 03:01 PM
                        • Wahaz
                          by Wahaz
                          10-30-2023, 08:42 PM
                        • grimacelord
                          Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
                          by grimacelord
                          Hello there.
                          I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
                          History:
                          1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
                          I searched for this error online and discovered...
                          03-15-2023, 03:29 PM
                        • to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                          by to5it0
                          Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                          I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                          This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                          I have opened the laptop and identified the main BIOS chip...
                          10-24-2025, 01:35 AM
                        • mkdj
                          Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                          by mkdj
                          Dear all,
                          I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                          Here the steps I have taken to fix the laptop:
                          - downloaded latest BIOS from Lenovo Website...
                          10-18-2025, 03:43 AM
