need remove password lenovo p52
    • 20682
    Re: need remove password lenovo p52
    Originally posted by HoulScreamPL
    Hello, i have problem with removing bios password from Lenovo P52. I've tried lenovo autopatcher method but after injecting patch just black screen and cpu getting hotter. Can u help me ? Original and patched dumps in attachmetns. Thanks
    You must post the Serial number
    • HoulScreamPL
      • Jun 2022
      • 9
      • Poland
      Sorry
      S/N: PF-1MR2B2 19/03
      TYPE: 20M9-0017MX
      • volinakis
        • Jan 2021
        • 2716
        • N/A
        Any chance for help ?
        try this and follow steps described in autopatcher
        • HoulScreamPL
          • Jun 2022
          • 9
          • Poland
          Still the same issue, i triple checked your patched file and still dont working.
          Just few restarts, black screen, cpu getting hot and beep code. Any other ideas ? I checked laptop still working on original bios file with password without problems.
          • volinakis
            • Jan 2021
            • 2716
            • N/A
            did you push cover switch? did you remove cmos battery? use a charger >130W, otherwise will not boot.
            • HoulScreamPL
              • Jun 2022
              • 9
              • Poland
              #26
              Cover switch is glued and secured by tape, ssd removed, cmos bat. removed, i use 230W Lenovo rectangle charger, tried on fully charged original battery and laptop behave like on charger, 2 restarts, black screen and beeps
              • volinakis
                • Jan 2021
                • 2716
                • N/A
                #27
                try this clean ME patched bios.
                • HoulScreamPL
                  • Jun 2022
                  • 9
                  • Poland
                  #28
                  On this bios still the same issue but i saw 4 restarts not 2 like before. I checked beep code and it says:
                  0285 - TCG-compliant functionality-related error (might be the TPM initialization failure)
                  • volinakis
                    • Jan 2021
                    • 2716
                    • N/A
                    #29
                    read again original bios chipset. I think you read it with errors 1st time.
                    • HoulScreamPL
                      • Jun 2022
                      • 9
                      • Poland
                      #30
                      U mean use original bios, turn on laptop etc. and after that read chip again and try patch it again ??
                      • osman68i
                        • May 2015
                        • 338
                        • The Netherlands
                        #31
                        ThinkPad P52 NM-B562
                        ​for someone who need information
                        32 mb bios you must read write mec1653. 1 resistor switch 4 jumper wire.
                        • feherhollo
                          • Nov 2019
                          • 110
                          • Hungary
                          #32
                          How can you read and write MEC1653? Where is the JTAG ports? I have T580 LTS-2 17812-1 board and cannot find the JTAG to work with the MEC
                            SMDFlea commented
                            Editing a comment
                            Off topic.This thread is only for the ThinkPad P52,and the post above yours is for the NM-B562 motherboard
                        • MConstantin
                          • May 2024
                          Hello 👋🏻
                          Is there anyone left here that could help me remove a password from BIOS? I've found some .bin files online, didn't help...in addition, I've only located 2 chips on the motherboard one 32MB and another 1MB but in the downloaded bios dumps there were three files 32MB, 1MB and 256Kb... I don't even know where the third Chip is 🤦🏻 I have the 32MB and 1MB bin files I'll compress them ans post here if it's enough. I look forward to an answer and we'll go from there. Thanks
                          PS Disassembly of a Lenovo ThinkPad P52 is a BIG PAIN IN THE A** 🤣
                          • mahlon simwnaja
                            • Nov 2022
                            • 81
                            • south africa
                            #34
                            Good day
                            Anyone please help Deactivate of Compu trace
                            LENOVO P52
                            TYPE : 20MA-S5J800
                            S/N : PF-1N7ZDF
                            MOTHERBOARD MODEL : NM-B561​
                            • dejankeke
                              • Jun 2016
                              • 17
                              • serbia
                              #35
                              hello everyone, I have a lenovo p52 with a bios password, I tried with the autopecher but after starting with patched bios, I heard the melody and there is no picture on the screen.
                              in attachment i put original and patched bios, please help.
                              Lenovo P52 cpu i7-8750H
                              type 20M9-001GMX
                              SN PF-1F15RS
                                SMDFlea commented
                                Editing a comment
                                Post moved to P52 thread.
                            • volinakis
                              • Jan 2021
                              • 2716
                              • N/A
                              #36
                              type 20M9-001GMX
                              SN PF-1F15RS
                              try this file and follow steps from autopatcher. Use original adapter or >130W
                              • dejankeke
                                • Jun 2016
                                • 17
                                • serbia
                                #37
                                thank you for your efforts, the result is the same, the melody is heard and there is no image on the screen.
                                is there any solution?
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1222
                                  • France
                                  #38
                                  try chk
                                  • dejankeke
                                    • Jun 2016
                                    • 17
                                    • serbia
                                    #39
                                    Originally posted by Maxpower3
                                    try chk
                                    I tried, but the laptop starts up and shuts down immediately.
                                    here is my original bios with password​
                                    • dejankeke
                                      • Jun 2016
                                      • 17
                                      • serbia
                                      #40
                                      try chk
                                      maybe even on this model the pins can be reconnected and the bypass password can be done
