halOogh Guys,....^_~ anyone ahve a bios dump for this model? ASUS K501UX REV 2.0 TNX.....^_~
ASUS K501UX REV 2.0 BIOS
Tags: None
Re: ASUS K501UX REV 2.0
attached here is my dump bin fileAttached FilesLast edited by SMDFlea; 04-05-2020, 07:20 AM. -
bios plz testAttached FilesLast edited by SMDFlea; 04-05-2020, 07:20 AM.Comment
Hi everyone
I replaced the mainb of my Asus k501ux with a new one and in the bios under serial number there is clearly no serial number listed ... how do I enter the serial number of my machine in the bios
... I know that there are software for HP models that allow you to migrate the machine's data by inserting them into the bios
...can someone please give me an input if there are programs also for the Megatrends bios that allow you to write the machine's construction data into the bios?
Thank youComment
Thread merged.
Please use the forum search to find related threads where you can post your request.
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
- Provide a BIOS/EC dump if possible
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by DynaxSCHi,
Usually on ASUS boards it worked...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
by Anchar777Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
- Loading...
