HP8460p Product Information Not Valid
    On my elitebook 8460p, the sku / serial / CT .... numbers has get out of the bios. Don't know the reason . I've tryed many nbdmifit tool version from 1st page (HPSETxxx) of this thread without any luck. When i run the correct dmitool, i enter correct values from the laptop, then display the changes ans the end , but no changes seen from screen remains.
    Tryed BCU tool, no output errors , but no changes remained . Updating bios version didn't help.
    Anyone have already seen this issue?
    I've done a bios dump with my programmer , but i'm not confident how to update this binary .
    Thanks for help
    Re: HP8460p Product Information Not Valid
    Thanks for help
    Post here bios dump i will fix.
      Thank you !
      Here my bios dump with all infos numbers
        Thank you !
        Try this and post results
          Thanks imranromi . No DMI errors now.
          But it's not my DMI numbers. Is it possible you provide me a bios with my DMI numbers inside ? (tryed to change with nbdmifit.bat but have sku write error)
          Thank you
            Thank you
            Try this file or add own dmi information.
              Thank you
              This your file with your dmi info
              try and report
                With this bios, nothing on the screen, only wifi/audio/power led are on.
                  try and report
                  Thanks Claudiomfa. Unfortunately, nothing change with this bios. Still have DMI errors with blank serials/sku, etc...
                    Try this file and report if dmi info is ok
                      Thanks, it works. I was able to change my DMI info: serials/SKU/CT with nbdmifit . I just can't update my system configuration ID (mine is A0001C02) because of MPM Lock (and can't unlock). But i suppose it is not important.
                        Nice. If you need corrected system config ID read your bios chip again and post it here. I will correct to you
                          Ok. here we are :
                            I send you big thanks both Claudiomfa & imranromi for your excellent help & support !
                              Ok. here we are :
                              I need that you write your dmi info with nbdmifit and save all data you can, after that read bios chip again and post here.
                              On last upload bios I can't find any dmi information.
                                Strange, I've already updated my dmi info and my last bios update contains them.
                                Anyway, possible workaround is to update your bios you provided to me with my system configuration ID (A0001C02), and I'll re change my dmi after.
                                  Try that bios with only system id A0001C02
                                    i've loaded your latest bios , and under bios information, my DMI info still remains . All seems correct except system config id (A0001D02), but sounds not important.
                                      It seems to be encrypted. I can't locate any information from your computer on bin file. Even "elitebook" can't find in your file.
