HP8460p Product Information Not Valid
  • tlfrance
    • Jan 2020
    • 18
    • france
    On my elitebook 8460p, the sku / serial / CT .... numbers has get out of the bios. Don't know the reason . I've tryed many nbdmifit tool version from 1st page (HPSETxxx) of this thread without any luck. When i run the correct dmitool, i enter correct values from the laptop, then display the changes ans the end , but no changes seen from screen remains.
    Tryed BCU tool, no output errors , but no changes remained . Updating bios version didn't help.
    Anyone have already seen this issue?
    I've done a bios dump with my programmer , but i'm not confident how to update this binary .
    Thanks for help
  • imranromi
    • Jan 2015
    • 1291
    • Pakistan
    Re: HP8460p Product Information Not Valid
    Thanks for help
    Post here bios dump i will fix.
    • tlfrance
      • Jan 2020
      • 18
      • france
      Thank you !
      Here my bios dump with all infos numbers
      • imranromi
        • Jan 2015
        • 1291
        • Pakistan
        Thank you !
        Try this and post results
        • tlfrance
          • Jan 2020
          • 18
          • france
          Thanks imranromi . No DMI errors now.
          But it's not my DMI numbers. Is it possible you provide me a bios with my DMI numbers inside ? (tryed to change with nbdmifit.bat but have sku write error)
          Thank you
          • imranromi
            • Jan 2015
            • 1291
            • Pakistan
            Thank you
            Try this file or add own dmi information.
            • Claudiomfa
              • Nov 2015
              • 455
              • Portugal
              Thank you
              This your file with your dmi info
              try and report
              • tlfrance
                • Jan 2020
                • 18
                • france
                With this bios, nothing on the screen, only wifi/audio/power led are on.
                • tlfrance
                  • Jan 2020
                  • 18
                  • france
                  try and report
                  Thanks Claudiomfa. Unfortunately, nothing change with this bios. Still have DMI errors with blank serials/sku, etc...
                  • Claudiomfa
                    • Nov 2015
                    • 455
                    • Portugal
                    Try this file and report if dmi info is ok
                    • tlfrance
                      • Jan 2020
                      • 18
                      • france
                      Thanks, it works. I was able to change my DMI info: serials/SKU/CT with nbdmifit . I just can't update my system configuration ID (mine is A0001C02) because of MPM Lock (and can't unlock). But i suppose it is not important.
                      • Claudiomfa
                        • Nov 2015
                        • 455
                        • Portugal
                        Nice. If you need corrected system config ID read your bios chip again and post it here. I will correct to you
                        • tlfrance
                          • Jan 2020
                          • 18
                          • france
                          Ok. here we are :
                          • tlfrance
                            • Jan 2020
                            • 18
                            • france
                            I send you big thanks both Claudiomfa & imranromi for your excellent help & support !
                            • Claudiomfa
                              • Nov 2015
                              • 455
                              • Portugal
                              Ok. here we are :
                              I need that you write your dmi info with nbdmifit and save all data you can, after that read bios chip again and post here.
                              On last upload bios I can't find any dmi information.
                              • tlfrance
                                • Jan 2020
                                • 18
                                • france
                                Strange, I've already updated my dmi info and my last bios update contains them.
                                Anyway, possible workaround is to update your bios you provided to me with my system configuration ID (A0001C02), and I'll re change my dmi after.
                                • Claudiomfa
                                  • Nov 2015
                                  • 455
                                  • Portugal
                                  Try that bios with only system id A0001C02
                                  • tlfrance
                                    • Jan 2020
                                    • 18
                                    • france
                                    i've loaded your latest bios , and under bios information, my DMI info still remains . All seems correct except system config id (A0001D02), but sounds not important.
                                    • Claudiomfa
                                      • Nov 2015
                                      • 455
                                      • Portugal
                                      It seems to be encrypted. I can't locate any information from your computer on bin file. Even "elitebook" can't find in your file.
                                      • rex98
                                        HP DMI Tool
                                        by rex98
                                        HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                        DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                        The DMI Tool given here are for personal use only.
                                        DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                        You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                        from it, and that you please credit the author...
                                        07-02-2025, 05:51 AM
                                      • pieciak
                                        HP 820 G1 - Product Information not Valid
                                        by pieciak
                                        Hello, HP 820 G1 laptop - "Product Information not Valid" error when turned on, you have to press enter and stop to understand the HP BIOS Configuration Unit according to the guide
                                        on YouTube: https://tiny.pl/dq69t
                                        However, at the very beginning I get this error:
                                        <ERROR msg="Unable to process command. Password is set, but no password file is provided" /> <ERROR msg="BCU return value" real="10" translated="10" />
                                        Can anyone help me so that I don't have to press enter every time? Help...
                                        02-22-2024, 08:57 AM
                                      • crash_10uk
                                        HP Notebook - 15-Ac107na Product Informaion Not Valid
                                        by crash_10uk
                                        Hi all hope you can help.
                                        A customer asked me to take a look at her Notebook. Upon booting the notebook and message appears.
                                        Product Information to valid
                                        The Following product information programmed into the system board is missing or invalid
                                        System Board (00A) - System Board CT Number
                                        The Notebook is a HP Notebook - 15-Ac107na
                                        Does anyone have the proper DMI tools for this, i have tried a few and all i get is "accessed denied" when trying to set new config
                                        I would be greatful for any help
                                        03-25-2023, 05:49 AM
                                      • salim5566
                                        loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                        by salim5566
                                        Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                        06-26-2025, 03:25 PM
                                      • DireXT
                                        Hp 350 g1 product information not valid problem
                                        by DireXT
                                        Is there anyone who can do something about this? I don't have the old backup, the customer has been waiting for 2 months and I've been looking for a solution to this problem everywhere ....
                                        09-30-2024, 10:21 AM
