HP 820 G1 - Product Information not Valid
  • pieciak
    • Feb 2023
    • 5
    • Poland
    Hello, HP 820 G1 laptop - "Product Information not Valid" error when turned on, you have to press enter and stop to understand the HP BIOS Configuration Unit according to the guide
    on YouTube: https://tiny.pl/dq69t
    However, at the very beginning I get this error:
    <ERROR msg="Unable to process command. Password is set, but no password file is provided" /> <ERROR msg="BCU return value" real="10" translated="10" />
    Can anyone help me so that I don't have to press enter every time? Help
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    See this how to do it but you need the information
    https://youtu.be/ttP1aL0u8Ws?si=qlJrz3xCusyZXedh
    • rex98
      • Feb 2023
      • 1297
      • Mandaue CEBU, Philippines
      upload your original bios dump in bios request thread. I'll try to recover the DMI data.
      • pieciak
        • Feb 2023
        • 5
        • Poland
        I have all the data to enter
        I tried the Dmi Firmware interface tool and I keep getting an error that there is a password, but I don't have any password because I normally go through the BIOS and change the settings, but returning to the DMI Firmware Interface tool, the laptop was turned on in program mode according to the instructions:
        If you are programming a 2012 or later model, you should use wndmifit utility (from the flash drive that you created)
        If you are getting MDM (manufacture programming mode) locked, the do the following:
        1. Shut down notebook
        2. Press WIN+UP+DOWN and the power button, HOLDING IT FOR at least 2 seconds
        3. When the laptop starts, you should see a message with red color that you are in programming mode.
        4. Use wndmifit utility from your operating system (Windows) to program the motherboard
        after entering all the data, an error appears as in the photos and the logs contain information about a password... I also showed it in the photo​
        • pieciak
          • Feb 2023
          • 5
          • Poland
          • BMCappelletti
            Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
            by BMCappelletti
            Hi everyone.
            Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
            Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
            Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
            02-18-2025, 12:22 PM
          • crash_10uk
            HP Notebook - 15-Ac107na Product Informaion Not Valid
            by crash_10uk
            Hi all hope you can help.
            A customer asked me to take a look at her Notebook. Upon booting the notebook and message appears.
            Product Information to valid
            The Following product information programmed into the system board is missing or invalid
            System Board (00A) - System Board CT Number
            The Notebook is a HP Notebook - 15-Ac107na
            Does anyone have the proper DMI tools for this, i have tried a few and all i get is "accessed denied" when trying to set new config
            I would be greatful for any help
            03-25-2023, 05:49 AM
          • DireXT
            Hp 350 g1 product information not valid problem
            by DireXT
            Is there anyone who can do something about this? I don't have the old backup, the customer has been waiting for 2 months and I've been looking for a solution to this problem everywhere ....
            09-30-2024, 10:21 AM
          • Woodsworth
            PS3 CECHC03 60GB YLOD Troubleshooting
            by Woodsworth
            I have a post on psx-place for this but thought I'd try here as well in case anyone has experience or the schematics or any kind of help. Here's the original post from psx-place:
            START
            Hi, so I bought a YLOD Fat PS3 as I wanted a repair project and thought it would be a good way to get experience. I was able to solder to the RX, TX and Diag pads on the COK-002 motherboard and was able to get external access and retrieved the codes. I haven't powered it on beforehand so these should be the last ones. I did try to get internal access immediately after but kept getting scopen response...
            03-19-2024, 07:58 AM
          • MrRoo
            HP laptop model 17-y018cy Halt on boot
            by MrRoo
            I have a 6-year-old HP laptop model 17-y018cy
            on every boot "product information not valid" is shown and that the product name, serial and system board numbers are missing and press enter to continue, I have contacted HP Uk but they can't help me.
            Anyone know of a way of stopping it showing or entering the information required as it bugging me
            Thanks in advance Andrew...
            02-06-2023, 10:29 AM
