clevo p650sg u37 and u38 bios dump request
  • ahnic
    • Mar 2017
    • 8
    Hi Do you have u37 and u38 bios dump of clevo p650sg so that I can use CH341a to program the chips? The motherboard model is 6-71-p6500-d03.Thanks in advance!
  • peste
    • Dec 2016
    • 12643
    • ROMANIA
    Re: clevo p650sg u37 and u38 bios dump request
    https://www.badcaps.net/forum/showth...t=clevo+p650sg
    • ahnic
      • Mar 2017
      • 8
      It seems that they are for P650SE. But I will try them. Thanks
        • 20682
        Bios + EC, BACKUP and VERIFY both your bios first before flashing the new ones . Flash the EC from windows,read the Read me file in EC folder .
        Bios http://repo.palkeo.com/clevo-mirror/P65xSG/
        Service Manual http://repo.palkeo.com/clevo-mirror/...P65XSG_ESM.zip
        • ahnic
          • Mar 2017
          • 8
          Thanks SMDFlea.The machine is currently not posting and I took out the motherboard and de solder U37 and U38. I read the content of them using CH341a programmer. Should I flash the attached zip file to U37 and U38 using CH341a programmer directly? How to VERIFY the bios first? Thanks again
            • 20682
            Theres a good CH341A programming guide over at win-raid,read part 2. https://winraid.level1techs.com/t/gu...rammer/32948/3
            https://mh-nexus.de/en/hxd/
            • ahnic
              • Mar 2017
              • 8
              Hi, Your attached zip files for u37 and u38 are official bios files and cannot be directly used to CH341a program the chips after unzip. How can I convert your official unzip bios files to bin files so that I can directly CH341a program the chips? Thanks
                • 20682
                See the Attached Files in my post. Download the 2MB and 4Mb zip files,extract each using winrar or 7-zip to get the bin files. If you`re having problems with the CH341A then try ASProgrammer,its a good software alternative https://www.badcaps.net/forum/showpo...6&postcount=10 .Choose the bios chip manually.
                • dridzz
                  • Apr 2020
                  • 3
                  • bra
                  How to locate the two bios chips? And which one is which ?
                  • d4wec
                    • Nov 2024
                    See upon the link for the service manual, so as i know, the u37 has the bios rom 4mb and u38 has the ME rom 2mb. There are located in the side where are the ram slot.
                    • TacticalFahrrad
                      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                      by TacticalFahrrad
                      I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                      BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                      06-30-2025, 04:09 AM
                    • hyperwood
                      [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
                      by hyperwood
                      I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
                      The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
                      I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
                      ✅ What I need:
                      • A working 2MB BIOS dump
                      • Matching NM-E471 Rev. 2.0, e.g. JY575
                      06-25-2025, 02:28 PM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • hotcrossedbuns999
                      M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                      by hotcrossedbuns999
                      My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                      1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                      2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                      3. I could only locate two chips that look like bios chips. Could someone verify this
                      01-03-2025, 12:32 PM
