clevo p650sg u37 and u38 bios dump request
  • ahnic
    • Mar 2017
    • 10
    Hi Do you have u37 and u38 bios dump of clevo p650sg so that I can use CH341a to program the chips? The motherboard model is 6-71-p6500-d03.Thanks in advance!
  • peste
    • 13924
    • ROMANIA
    Re: clevo p650sg u37 and u38 bios dump request
    https://www.badcaps.net/forum/showth...t=clevo+p650sg
    • ahnic
      • Mar 2017
      • 10
      It seems that they are for P650SE. But I will try them. Thanks
        • 22293
        Bios + EC, BACKUP and VERIFY both your bios first before flashing the new ones . Flash the EC from windows,read the Read me file in EC folder .
        Bios http://repo.palkeo.com/clevo-mirror/P65xSG/
        Service Manual http://repo.palkeo.com/clevo-mirror/...P65XSG_ESM.zip
        • ahnic
          • Mar 2017
          • 10
          Thanks SMDFlea.The machine is currently not posting and I took out the motherboard and de solder U37 and U38. I read the content of them using CH341a programmer. Should I flash the attached zip file to U37 and U38 using CH341a programmer directly? How to VERIFY the bios first? Thanks again
            • 22293
            Theres a good CH341A programming guide over at win-raid,read part 2. https://winraid.level1techs.com/t/gu...rammer/32948/3
            https://mh-nexus.de/en/hxd/
            • ahnic
              • Mar 2017
              • 10
              Hi, Your attached zip files for u37 and u38 are official bios files and cannot be directly used to CH341a program the chips after unzip. How can I convert your official unzip bios files to bin files so that I can directly CH341a program the chips? Thanks
                • 22293
                See the Attached Files in my post. Download the 2MB and 4Mb zip files,extract each using winrar or 7-zip to get the bin files. If you`re having problems with the CH341A then try ASProgrammer,its a good software alternative https://www.badcaps.net/forum/showpo...6&postcount=10 .Choose the bios chip manually.
                • dridzz
                  • Apr 2020
                  • bra
                  How to locate the two bios chips? And which one is which ?
                  • d4wec
                    • Nov 2024
                    See upon the link for the service manual, so as i know, the u37 has the bios rom 4mb and u38 has the ME rom 2mb. There are located in the side where are the ram slot.
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • haitham sharabati
                      by haitham sharabati
                      Hello engineers šŸ˜€,
                      I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
                      šŸ”§ Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      šŸ’€ Problem:šŸ˜…
                      - Device shows ā€œAdministrator Passwordā€...
                      08-07-2025, 04:54 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • greelidd
                      K6604J Vivobook RTX 4070 BIOS Dump Request
                      by greelidd
                      Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
                      Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
                      09-01-2025, 06:14 PM
                    • olfelys
                      HP Pavilion 500-560nf (Memphis-S, SSID 2B2C) – BIOS dump request (8 MB .bin)
                      by olfelys
                      Request: Looking for a BIOS dump for HP Pavilion 500-560nf (SKU L1V04EA), motherboard Pegatron Memphis-S / SSID 2B2C.
                      My board enters jumper recovery mode but no BIOS files are available from HP anymore.
                      I need the full 8 MB BIOS dump (.bin) (with .sig/.s12 if possible), or at least a clean dump I can flash with CH341A.
                      Already checked HP support & Win-Raid packages (they only contain Intel ME firmware, not the BIOS).
                      post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it,...
                      09-05-2025, 12:38 AM
