HP ZBook 17 G2 Locked BIOS Dump
  • idog
    I fumble
    • Aug 2022
    • 14
    • Netherlands
    #41
    Re: HP ZBook 17 G2 Locked BIOS Dump
    fyi. Found the correct ic next to the cpu. Didn't need to take out the motherboard, I could reach it after removing the keyboard.
    • Mazorca
      • Jan 2017
      • 463
      Read the chip three times at least, compare with hex editor using analysis tab, two at a time, remember you are messing with the BIOS bin, it could brick (momentarily) your laptop. But you have the entire knowledge base of the Badcaps members backing you up. Do not rely on clip, it gives bad reading sometimes, that's why you get three or more readings. After flashing, do not rely on auto-verification, verify again, by doing a fourth reading and comparing to unlocked bin file. If you get no video, wait a few minutes. Thanks for the info regarding location.
      • idog
        I fumble
        • Aug 2022
        • 14
        • Netherlands
        #43
        Thanks for the tips ! I took it off btw, I don't use clips. All 4 dumps (overcautious, I know) were identical. Also writing, verifying, dump again and compare. All checks out. Testing it tomorrow when the owner brings their powercord
        • idog
          I fumble
          • Aug 2022
          • 14
          • Netherlands
          #44
          Tomorrow was almost 2 months later. Apparently they weren't in a rush..Anyway, now they finally bring me the charger, but it's not the correct charger so it seems. It requires a 19.5v/10.3a charger. They bring me a 19.5v/4.62a one. Now I know a little bit less amps doesn't hurt it, but with this difference I guess the behaviour of the laptop is to be explained (fast blinking powerbutton and capslock when the charger is plugged in). To be continued...
          • idog
            I fumble
            • Aug 2022
            • 14
            • Netherlands
            #45
            So, turned out the charger was not the correct one. I now have the correct charger AND the correct battery (was also not supplied the first time around).
            It is now unfortunately not working. I see the charging led, but when I turn on the laptop it immediately turns off again. Anyone recognizes this behaviour ?
            Since the writing of the bios went okay (I guess, will verify later) I am focusing on something I may have botched.
            Remember I mentioned I was taking off the other bios chip first (the wrong one ). While doing that I managed to damage one of the 8 pads that chip was soldered on to. Although I made a jumper to fix that I am unsure whether or not that did the trick. Does anyone have a schematic for the zbook 17 g2 motherboard so I can find an alternative point I can solder the jumper to ?
            If that is not the cause of the turn on/turn off behaviour, then maybe it's the actual modified firmware (I put in all zeroes (lowvalues) in the designated area instead of all F's (highvalues)). Or do you guys think either should work ?
            Much obliged for your patience and any help you can offer !
            Dennis
              • 21662
              Dennis
              Laptop schematic requests go here -> https://www.badcaps.net/forum/forumdisplay.php?f=41 ,use the forum search function as well,it might already be posted.
              • idog
                I fumble
                • Aug 2022
                • 14
                • Netherlands
                #47
                Thanks ! I saw this post already requesting it (https://www.badcaps.net/forum/showth...light=LA-B391P). I admit, he could be more polite about it, but I don't think there's added value in me creating a new post for the exact same schematics, so I'll just keep on eye on that post.
                • idog
                  I fumble
                  • Aug 2022
                  • 14
                  • Netherlands
                  #48
                  So, trying to make headway here, but unfortunately the laptop was giving me the silent treatment. All it does now when I turn it on (or when I connect the powercord without a battery in the laptop) is turn on for a second, all the leds (keyboard leds + power + wifi + volume) will light up for a second and it will turn off again. This keeps happening until I unplug it.
                  Thinking something might have been wrong with the firmware I wrote, I wrote back the original firmware (read back and verified). So the locked one.
                  Unfortunately, this is still giving me the same behaviour.
                  The only thing I can imagine is I somehow messed up the surestart bios ic (the small capacity one I mistook for being the actual bios ic in the beginning). I tore one of the pads underneath that one, and I created a jumper for it, but that might be incorrect.
                  Time to start looking for a replacement motherboard or does anyone have the golden tip here. It's not the bios firmware anymore, I've rewritten it a couple of times now, and it's identical every time. Really suspecting the surestart ic pads (I didn't write anything to that ic, btw).
                  • idog
                    I fumble
                    • Aug 2022
                    • 14
                    • Netherlands
                    #49
                    Ok, so.. I managed to get it to life again. The pad which I tore was not only connected to the via, but also to the capacitor nearby. Made a full jumper and it's back to life. Now for the actual password stuff
                    • idog
                      I fumble
                      • Aug 2022
                      • 14
                      • Netherlands
                      #50
                      And ... all is well now. Password is gone, everything works. Only took over 2 months from start to finish. And all that for a fourth generation cpu.. ah well. It's the journey I guess
                      Thanks all !
                      • munir100
                        • Dec 2018
                        • 187
                        • uae
                        #51
                        Hp zbook 17 g2 la-b3912p let dispaly problem here is bios
                        • hardware1
                          • Sep 2021
                          • 2946
                          • N/A
                          #52
                          Try.
                          all donations are welcome,
                          • munir100
                            • Dec 2018
                            • 187
                            • uae
                            #53
                            Thanks perfect work well done
                            • eho0
                              • Dec 2020
                              • pl
                              #54
                              Re: HP ZBook Locked BIOS Dump
                              Hey everyone.
                              I have BIOS Admin password locked dump file.
                              Please let me know if this can be unlocked.
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #55
                                Originally posted by eho0
                                Hey everyone.
                                Read the rules before posting:
                                BIOS guides, methods, resources and tools
                                Password removal by laptop brand
                                Become a Badcaps supporter
                                Thanks to all supporters.
                                • NBVJXF
                                  • Dec 2021
                                  • russia
                                  #56
                                  What settings need to be set in bios to activate intel graphics card on zbook 17 g2 ? I can not turn on. once appeared for 5 minutes and then disappeared.screen went out
                                  • Ahari
                                    by Ahari
                                    I...
                                    08-13-2025, 06:12 AM
                                  • Habble7
                                    by Habble7
                                    Suspected Cause:
                                    Troubleshooting Attempts:
                                    05-22-2025, 07:28 AM
                                  • ArkzG
                                    [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                    by ArkzG
                                    Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                    What I currently have available:
                                    - Model: FA506NF (2021)
                                    - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                    - Tools: CH341A programmer ready to use
                                    Does anyone have either a clean 2MB .bin dump of this model,...
                                    09-26-2025, 09:34 PM
                                  • haitham sharabati
                                    by haitham sharabati
                                    Hello engineers 😀,
                                    🔧 Device Info:
                                    - Model: HP 15-da2007ne
                                    - Product Number: 8XF55EA#ABV
                                    - Serial Number: CND0338P0D
                                    - CPU: Intel Celeron N4000
                                    💀 Problem:😅
                                    08-07-2025, 04:54 AM
                                  • Citymin
                                    by Citymin
                                    S/N : 5RNK9FFT70...
                                    08-05-2025, 05:12 AM
