Asus ux305ca rev 2.0 bios dump clearme
  • ace.code
    • Apr 2016
    • 133
    • Estonia
    Can someone please clear me this bios dump it worked for me but takes too long to boot
  • peste
    • Dec 2016
    • 13920
    • ROMANIA
    Re: Asus ux305ca rev 2.0 bios dump clearme
    try...
    • ace.code
      • Apr 2016
      • 133
      • Estonia
      Originally posted by peste
      try...
      sorry for the wait but still it takes 5 to 7 sec to boot
      • Claudiomfa
        • Nov 2015
        • 455
        • Portugal
        Do you have original dump?
        Try this attached bios but your first uploaded file is original factory file. If that´s not work, maybe your upload as wrong file for your model.
        • ace.code
          • Apr 2016
          • 133
          • Estonia
          this the original dump but it wont power the laptop
          • peste
            • Dec 2016
            • 13920
            • ROMANIA
            Try...
            • ace.code
              • Apr 2016
              • 133
              • Estonia
              Try...
              SOORY FOR TAING TOO LONG
              IT WORKS MAN THNXXXXXXX
              • mkdj
                by mkdj
                Dear all,
                10-19-2025, 04:41 AM
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • pirati
                by pirati
                10-27-2025, 04:20 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • Ahari
                by Ahari
                I...
                08-13-2025, 06:12 AM
