Can someone please clear me this bios dump it worked for me but takes too long to boot
Asus ux305ca rev 2.0 bios dump clearme
Re: Asus ux305ca rev 2.0 bios dump clearme
try...Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs. -
Do you have original dump?
Try this attached bios but your first uploaded file is original factory file. If that´s not work, maybe your upload as wrong file for your model.Attached Filesif you find these attachements useful please consider making a small donation to the site
Try...Attached Filesif you find these attachements useful please consider making a small donation to the site
Every donation made will go towards server fees and maintenance costs.Comment
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
- Loading...
