ThinkPad Thunderbolt 3 Firmware
  • zomi
    • Nov 2011
    • 505
    Re: ThinkPad Thunderbolt 3 Firmware
    worked a treat
    • zlo13666
      • Apr 2023
      • 8
      • Ukraine
      Possible my post will save for someone his own p52s. I found that thunderbolt chif after flashing show only zeros. Im ordered same chip 2 euro and flash it with with NeoProgrammer and bin from the latest update(before conferted it to 1mb size) and now usb c port working fine!
      • t34v2
        • Mar 2014
        • 25
        • poland
        Is there such firmware available for Lenovo Thinkpad E14 Gen2 ? I have USBC issue and i think it might be TB firmware fault.
        • xpmaster
          • Mar 2017
          • Austria
          i flashed firmware to chip Dock is now recognized as Billboard 3 ? but Thinkpad will not charge and no Thunderbolt controller in device manager.
          Lenovo Thinkpad X1 7 gen 20qd.
          Can someone help or have dump from this device.
          This is dump from my chip
          • Mcnick 3
            • Mar 2024
            • 7
            • Poland
            Hello, i have a ThinkPad P52s with an i7 8th gen, the laptop charges slowly when it is turned off (i'm using lenovo 65w charger) i can't find any thunderbolt controller in device manager, "Thunderbolt BIOS Assist Mode" and "Wake by Thunderbolt (TM) 3" is disabled in bios, "Security Level" is set to "User Authorization", the intel thunderbolt software doesn't detect it. Which files should i flash? Which chip is it and where is it located?
              • 20745
              Try to install the firmware from lenovo support.Its listed under " USB Device, FireWire, IEEE 1394, Thunderbolt" at the drivers and software support page
              • Mcnick 3
                • Mar 2024
                • 7
                • Poland
                #27
                I tried, it does nothing.
                • Whale linguini
                  • May 2024
                  • 30
                  Does anyone have FW for a p14s Gen 2?
                  • Qbanastyle
                    • Jun 2020
                    • 6
                    • Polska
                    #29
                    Hello! I confirm that the problem has been solved in Lenovo t480 i7 type 20L6. Regardless of the connected charger, it displayed the information "The connected AC adapter has a lower wattage than the recommended model which was shipped with the system". Using ch341a and neoprogrammer, I managed to: 1) upload zeros, 2) upload TBT.bin. The laptop works on a 65w charger, reports no problems, and thunderbolt appeared in the device manager. Thank you for helping me solve the problem!
                    • laptopgreen
                      • Aug 2017
                      • 18
                      • VN
                      #30
                      Thanks sir.
                      • ali0robot
                        • Mar 2023
                        • 69
                        • N/A
                        #31
                        I had fallowed same thing with tbt and assist tbt that extend with zero to make a 1Mb file, after reprogramming charging LED flashing purple but after a while again message appear and voltage on type c port is 5V.
                        laptop is t480s-20L8
                        original file attached
                        serial number: pc11acj2
                        thanks in advance
                          • 20745
                          thanks in advance
                          Maybe this post will help - https://www.badcaps.net/forum/troubl...33#post1679233 .Flash all zeros first and boot, then try the firware
                          • ali0robot
                            • Mar 2023
                            • 69
                            • N/A
                            #33
                            after this method result is same as before just 5V on type c port
                            • Maxpower3
                              Brand name and Model Type for Lenovo error 2202 product name is invalid
                              by Maxpower3
                              Info for error 2202 LenovoThinkPad models and type
                              Extract from ThinkPad Maintenance Utilities Configuration File
                              plnsrv.ini Version 1.01
                              Some information that may be useful
                              There must also be missing models, add them to the list if you know of any.
                              Code:
                              brand name
                              20B1=ThinkPad Edge E445
                              20B2=ThinkPad Edge E545
                              20BC=ThinkPad Edge E145
                              20BM=ThinkPad X140e
                              20BL=ThinkPad X140e
                              20A3=ThinkPad X230s
                              20AH=ThinkPad X230s
                              20AK=ThinkPad X240s
                              20AJ=ThinkPad X240s
                              02-21-2024, 10:27 AM
                            • TheUser
                              Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                              by TheUser
                              Hello to everyone ,
                              This is my first post here, and i would like to share with you a small story in case you can help me.
                              Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                              All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                              I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                              02-10-2024, 02:07 PM
                              Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook Yoga Specification for Upgrade or Repair
                              This specification for the Lenovo ThinkPad ThinkPad X1 Titanium Yoga Gen 1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkPad X1 Titanium Yoga Gen 1 boardview and ThinkPad X1 Titanium Yoga Gen 1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                              09-07-2024, 04:10 AM
                              Lenovo ThinkPad P1 + ThinkPad Thunderbolt 3 Workstation Dock Mobile workstation P Specification for Upgrade or Repair
                              This specification for the Lenovo ThinkPad P1 + ThinkPad Thunderbolt 3 Workstation Dock Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P1 + ThinkPad Thunderbolt 3 Workstation Dock boardview and P1 + ThinkPad Thunderbolt 3 Workstation Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the...
                              09-06-2024, 08:58 AM
