Re: Hp ellİtebook 840 g5 bios password
not working just black screen and current 221ma
Hp elitebook 840 g5 bios password
is there any solution to the system end point controller issue?. I have 6050A2945601 with bios issue. I dont have the orig dumps as this came to me as dead, both ec and bios chip were worked on before. Found this bios and the unit powers up again but I now get the endpoint controller issue.Leave a comment:
is there any solution to the system end point controller issue?. I have 6050A2945601 with bios issue. I dont have the orig dumps as this came to me as dead, both ec and bios chip were worked on before. Found this bios and the unit powers up again but I now get the endpoint controller issue.Attached FilesLeave a comment:
You MUST NOT:- Hijack threads unrelated to your request
You MUST:- Read BIOS guides, methods, resources and tools
- Try the method at BIOS guides, methods, resources and tools before requesting help
- Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
- Post under a related thread if it exists
- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
.Leave a comment:
Re: HP BIOS unlock tool
Hello friends, i have this hp elitebook 840 g5. hp unlocker not working, password still present. I need some help.
There's original dump.Attached FilesLeave a comment:
There is a password in bios. can you help me pleaseAttached FilesLeave a comment:
try thisLeave a comment:
840 G5 locked
Hello
i tried to remove the bios password from a 840 G5 with a program (32mb chip) now the caps lock and num lock keys blink 3 times and the fans spin all the time (screen stays black. when i restore the original bios file games on it comes again the same problem with the flashing keys and the fan. what can it be? can someone help me?
edit: its a 840 g5 not g6Attached FilesLeave a comment:
Hi , I have a HP 840 G5 with bios password, can anyone please help to remove password. I have attached the main bios file. Thank yoy
Channel: BIOS Requests ONLY!
by traxformaniaHello,
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... -
by tlindiSublect line continuation: ... Jaguar IDS PC aka Panasonic
Ack
Ack
by NopslideHello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....-
by BlackVisorRedmiBook Pro 1542022 6800H
SKU: TM2113-39463
Model Number: RMA2204-AB
CMIIT ID: 2022AP1835
SN: 39463/22WD01355
BIOS version: RMARB5B0P1010 20230628
1. I bought this laptop from flea market, and the seller said that he had never set a password, however here is a password required when pressing F2 to enter BIOS.
2. And after entering incorrrect password 3 times, there is no any useful information like "recovery code"
3. I used universal bios backup tool, and dumped 8MB bin file, but hex code after "SystemSupervisorPw" is...-
01-14-2024, 06:35 AM -
- Loading...
