Originally posted by Mykyta Khruslov
View Post
Hp elitebook 840 g5 bios password
Hi. Somebody help please. BIOS PASS --- Thanks a lot!
HP EliteBook 840 G5
Chip -- W25Q256JV
S/N -- 5CG9052CP3
MB -- L15516-601
P/N -- 2FA64AV
I did reprogram the main chip with bin file you provided but i also de assembled and reprogrammed the chip which is located at back of board. Saved original bin then unlocked with hp unlocker. But laptop doesn't power up now no sign of light even the charging plug on. No light on keyboard.
Originally posted by lovepreet fatehpur View PostHi request to unlock bios HP ELITEBOOK 840 G5
i tried to unlock with hp unlocker but password still there.
productid 6AU11UP#ABA
SN 5CG9292NXS
i have read most of posts about unlocking the bios but i am so confused could you please tell me all steps just for my case
i am attaching dump file
Serial_5CG9292NXS
Sku_6AU11UP#ABA
Fearture byte_3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqhKhkj4jh.mh
Build Id_17WWCSCT601#SABA#DABA
CT Number_6GPRE05WYAS7WBAttached Files
SN 5CG9292NXS
i am attaching dump fileAttached Files
Originally posted by Ado02 View Post
Thank you for your help. I followed your instructions but encountered an issue. I received a message indicating that the BIOS blocks don't match and that I need to update the BIOS. However, when I reached the battery screen (the battery capacity error message due to the battery not being connected), the system froze.
Upon restarting the laptop, I observed six orange flashes and then nothing happened. I removed the chip again and compared the files, noting that some changes had been made.
Do you have any suggestions on how to proceed?
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
after following my instruction to get rid of Manufacturing mode. use BCU.
Serial Number: 5CG85033FH
Product #/SKU: 3UP81ET#ABU
CT Number: PGWNQ00WBBO1RJ
Description: HP EliteBook 840 G5
BuildID: 17WWCSBT602#SABU#DABU
Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAgdhKhkjh.GE
MAC Address : E4:E7:49:9E:89:F2Attached Files
Originally posted by rex98 View Post
only flash this 16mb
Originally posted by Ado02 View PostCould someone please help remove the password from the attached files?
I've attempted using the unlock tool, but it still prompts me for the password.
Attached are the files from both ICs and the unlock files as well.
SN: 5CG85033FH
Model: HP EliteBook 840 G5
Motherboard: COMPUTRO-6050A3079801-MB-A01
Thank you!Attached Files
Originally posted by peste View Post
read the rules..https://www.badcaps.net/forum/troubl...before-posting
post the S/N, , the motherboard model, the full name and model of the laptop,
etc.
Thank you!
etc.
SN: 5CG85033FH
flash this main and the original locked EC.
after following my instruction to get rid of Manufacturing mode. use BCU. or flash the original main.
Originally posted by Echoo View PostHello!
I unlocked the bios password with RCUnlocker of the 840 G5, but since then every time I turn it on I get an HP Endpoint Security Controller problem. I am attaching the backup copy of the 32MB chip, please help me with the solution!
HP EliteBook 840 G5
PN: 2FA66AV
SN: 5CG8253GZD
after following my instruction to get rid of Manufacturing mode. use BCU. or flash the original main.Attached Files
Hello!
HP EliteBook 840 G5
PN: 2FA66AV
SN: 5CG8253GZDAttached FilesLast edited by Echoo; 05-30-2024, 12:49 AM. Reason: I tried to write about this in the appropriate topic, but there was no reply. Here it is disassembled on my desk...
Originally posted by viji90 View PostHP elitebook 840 g5 bios password clean
pls help me to my locked file
if your still having issues send the 16mb bios file.
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
pls help me to my locked fileAttached Files
Great, it's perfect. Thanks for your help.
Btw which tool do you use to extract machine specific info and to patch BIOS file?
