Another La-6062p rev2.0 with no power +19V Rail 3.3V ALWP + 5V ALWP ok , Flash Bios now the MB starts but no image 30 seconds shut down the fan spins fast last 10 seconds before shut down after 2-3 attempts the MB start working but the image is late and shut down 30 seconds fan spins fast is this BIOS fault
MB La-6062p rev2.0 No power
Re: MB La-6062p rev2.0 No power
Another La-6062p rev2.0 with no power +19V Rail 3.3V ALWP + 5V ALWP ok , Flash Bios now the MB starts but no image 30 seconds shut down the fan spins fast last 10 seconds before shut down after 2-3 attempts the MB start working but the image is late and shut down 30 seconds fan spins fast is this BIOS faultAttached Files----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae.. -
Why dont flash bios from toshiba official update?? I beleive you have sufficient experience to extract bios from webupdate.Comment
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Thread moved to bios requests section: https://www.badcaps.net/forum/forumdisplay.php?f=40Comment
by wolf1976hi
i have the above tv it turns on for few seconds and after shut down
can you suggest me what can be cause this problem ? -
by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
by twonk9098Hi all,
I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
I have tried a few new bios but exactly... -
by RolinI have a Lenovo Legion 5 15IMH05H 81y6003yUS that someone asked me to help them with a failing SSD. I installed a new SSD, fresh Win11 installation, updates, etc. Very standard stuff and everything was completed. He said he'll pick it up in a few days so I shut it down and set it aside.
A few days later came and now it won't POST an image, keyboard lights up, fans spin then shuts itself off after about 40 seconds. I've already tried the typical draining capacitance and removed CMOS battery,etc. No display on an external HDMI monitor as well.. No idea what happened. Suspected a BIOS... -
by liquidzorchHello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
- Loading...
