epk50 LA-G07DP LA-G07CP bios
i Need repair bios please
NO DISPLAY
Laptop: HP Notebook - 15-da0072ns core I7 GEN 8
MB model: EPK50 LA-G07CP. Rev:1.0
Serial number: CND83361DC
Attached FilesLast edited by SMDFlea; 12-08-2023, 03:14 AM.Comment
Attached FilesComment
I get one HP 250 g7 (la g07dp) that doesn't display with battery but display with charger.
I've Program bios but still the same thing.
And I've confirmed the battery from another PC and is perfectly working.
no short at battery terminal on board.
kindly be of help.
https://www.badcaps.net/forum/forumdisplay.php?f=23
Give as many details as possible about the voltage, resistance tests you've done so far.----------------------------------------------------------------------------------------------------------------------------------------------------------
Become a Badcaps supporter
Thanks to all supporters.
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
read the rules..https://www.badcaps.net/forum/troubl...before-posting
post the S/N, the original bios of the laptop,etc
Every donation made will go towards server fees and maintenance costs.Comment
Anybody fix this bios?
When press the power button, fan starts spinning but nothing happens.
3.3V,5V and Ram 1.2V are ok.
Only get 0.047A from power supply
EPK50 LA-G07DP
REV 1.0
S/N: Don't have because I only got the motherboard for repair.
Your BID is 084A6 ,the DMI is 210000 - 21103F
Use the Guides to find and extract a virgin bios
[Guide] How to find the right HP bios version to flash https://www.badcaps.net/forum/troubl...flash?t=122195
[Guide] How to extract ready for programming dump from HP update executable file https://www.badcaps.net/forum/showthread.php?t=121948
Copy the DMI (serial,feature Byte,win key) from your backup to the virgin bios using a hex editor.Select the same offsets (select block in HxD) in both bios,copy from the old,paste to the new.
Offsets: 210000 - 21103F
HxD Hex editor https://mh-nexus.de/en/hxd/
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
Channel: BIOS Requests ONLY!
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by BloodhoundjeHi everyone,
I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
I have desoldered the bios chip (GigaDevice...-
by TraJikar MacI need someone that can capsulate one of the bios files below, and i prefer the older bios version so i can flash it using CH341A tool into the bios chip.
The manufacturer BIOS files are bigger than the BIOSbackup1.bin files by 256KB and I don't know how to fix or recompile it.
You can see in this link a conversation between me and other people (Starting at page 10) who tried to help me (thanks to their efforts), but i still couldn't fix it and the laptop is considered as dead until now.
Also, I uploaded a backup file for the bios that I extracted by using CH341A...-
- Loading...
