hp 640 g2 password need bios dump
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #61
    Re: hp Probook 640 g2 bios password
    Originally posted by SMDFlea
    The ME firmware in your bios was corrupt.Try this bios with your pass removed and new ME firmware .
    Probably the chip was not read correctly, and the dump posted by theGenova is corrupted.
    Yes indeed, just checked the file too:
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Genova
      • Jan 2020
      • 118
      • FRANCE
      #62
      We are programming 640G2_ME CLEAN with AsProgrammer 1.41 with the unlock, erase, programm, verify.
      In progress...
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #63
        Originally posted by Genova
        How can i read in total commander the content of the chip ??
        Check the pictures:
        • Genova
          • Jan 2020
          • 118
          • FRANCE
          #64
          Originally posted by Vesko356
          Check the pictures:
          So after programming the file 640G2_ME CLEAN into the bios i need to save the the bios to a new file to compare ?
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #65
            After programming just close the AsProgrammer, open the program again, read the content of the chip, save the file as let's say TEST.bin, then compare the TEST.bin with the 640G2_ME CLEAN.bin with the Total Commander.
            • Genova
              • Jan 2020
              • 118
              • FRANCE
              #66
              The two files are identical
                VIP Moderator
                • Aug 2018
                • 4386
                • Bulgaria 🇧🇬
                #67
                Excellent, so you do the programming of the chip fine.
                Try to power up the laptop.
                • Genova
                  • Jan 2020
                  • 118
                  • FRANCE
                  #68
                  Exactly the same, num lock and maj flashing 7x
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #69
                    OK, since your initial dump was apparently corrupted there is no need to try again with it, try the dump in that post, it should be OK.
                    HERE:
                    • Genova
                      • Jan 2020
                      • 118
                      • FRANCE
                      #70
                      OMG you are amazing guys !
                      After some bip bip bip the laptop coming back to life.
                      Just a red message in top : blabla in manufacturing Mode....34
                      Enter in bios is good no password now
                      Have to go home, the rest of the adventure: tomorrow
                      Thanks again to all here for your precious help
                      • Genova
                        • Jan 2020
                        • 118
                        • FRANCE
                        #71
                        just a little feedback about manufacturing mode after flash with HP640G2 cleared ME region file.
                        After found all specs about the laptops, serial, uuid, etc..
                        Laptop is now fully functional thanks again to all member for help provided
                        • damian13030
                          • Mar 2020
                          • 10
                          • Polska
                          #72
                          Re: hp 640 g2 need bios dump
                          Hello I have HP probook 640g2, (i5 6300) I have fault 3/2 and 2/2 (bios) .Will the other bios from the posts above work?
                          • peste
                            • 13747
                            • ROMANIA
                            #73
                            put the bios backup here
                            • damian13030
                              • Mar 2020
                              • 10
                              • Polska
                              #74
                              Someone has already soldered, I don't know if it is original.
                              • peste
                                • 13747
                                • ROMANIA
                                #75
                                try..
                                • damian13030
                                  • Mar 2020
                                  • 10
                                  • Polska
                                  #76
                                  not work, the same fault.
                                  • peste
                                    • 13747
                                    • ROMANIA
                                    #77
                                    try that too..
                                    • damian13030
                                      • Mar 2020
                                      • 10
                                      • Polska
                                      #78
                                      not work.
                                        • 22109
                                        Originally posted by damian13030
                                        not work.
                                        Can you post a picture of the serial number on the base cover sticker, or write it here.
                                        • damian13030
                                          • Mar 2020
                                          • 10
                                          • Polska
                                          #80
                                          Stickers in motherboard
                                          • Buzzfuzz2k
                                            Bios password removal on a Unowhy dump
                                            by Buzzfuzz2k
                                            Hi Everyone,
                                            I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                                            The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                                            the Computer is a Unowhy small pc
                                            N° UYM6524702229
                                            After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                                            My first attempt was to get the bios dump from windows...
                                            11-13-2023, 07:37 AM
                                          • dell_bios
                                            Need unlocked BIOS dump for W25Q64FV (Admin Password removal)
                                            by dell_bios
                                            I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
                                            The board has three SPI flash chips:
                                            - W25Q64FV (main BIOS)
                                            - W25Q32FV (EC/TPM)
                                            - W25X10CL (configuration)
                                            I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
                                            The dump contains protection that needs to be removed.
                                            If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
                                            I’m also happy to share my dump for comparison if needed.
                                            Laptop model: [please specify, e.g....
                                            10-16-2025, 04:28 PM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • ArkzG
                                            [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
                                            by ArkzG
                                            Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
                                            What I currently have available:
                                            - Model: FA506NF (2021)
                                            - BIOS chip: GD25LQ16 (16Mbit/2MB)
                                            - Tools: CH341A programmer ready to use
                                            Does anyone have either a clean 2MB .bin dump of this model,...
                                            09-26-2025, 09:34 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
