Dell Latitude 7400 Bios Password
  • epicsmith
    • May 2022
    • usa
    #281
    Re: Dell Latitude 7400 Bios Password
    Can i get master password for G9CL793-8FC8
    • aissa med
      • Mar 2018
      • morocco
      #282
      Post your BIOS dump
      • tdot_steel
        • May 2022
        Can I get master password for 5KSD6D3-8FC8 please?
        • satishkumar
          • Sep 2015
          • 164
          • India
          #284
          post ur laptop bios backup
          or try
          https://bios-pw.org/
          • feherhollo
            • Nov 2019
            • 110
            • Hungary
            #285
            Can you unlock my locked dump? 8FC8
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria πŸ‡§πŸ‡¬
              #286
              Become a Badcaps supporter
              Thanks to all supporters.​
              • feherhollo
                • Nov 2019
                • 110
                • Hungary
                #287
                Originally posted by Vesko356
                Laptop won't turn on, Just caps lock led on.
                What is the problem? Itry to reflash
                • feherhollo
                  • Nov 2019
                  • 110
                  • Hungary
                  #288
                  Unfortunately your file not working. Original file is ok. I have tested it.
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria πŸ‡§πŸ‡¬
                    #289
                    Should work, most probably you didn't programmed the chip properly (with verification) or didn't solder the chip as it should.
                    Try again.
                    • feherhollo
                      • Nov 2019
                      • 110
                      • Hungary
                      #290
                      Try again.
                      I reflashed the chip. Verified ok. Now working just high ventilation in factory mode which was confused me. Everything okay now. I'm happy that you erased the service tag region also. Very good work. Many thanks
                      • sosphemy
                        • Jun 2022
                        • Mexico
                        #291
                        where can I contact you?
                        I need to unlock a Dell Latitude 7400 Laptop.
                        59VBYY2-8FC8.
                        Please
                        • ForestFan
                          • Jun 2022
                          #292
                          Can anybody help with the bios admin password for my 7400?
                          System Number: 8SFJ1Z2-8FC8
                          • feherhollo
                            • Nov 2019
                            • 110
                            • Hungary
                            #293
                            59VBYY2-8FC8.
                            Please
                            You need to dump your bios chip content and reflashed the chip using patched content. Master password not available for free.
                            • feherhollo
                              • Nov 2019
                              • 110
                              • Hungary
                              #294
                              You need to dump your bios chip content and reflash the erased chip with patched content. Master password not available for free for these new 8FC8 suffix...
                              • 8bit4k
                                • May 2022
                                • El Salvador
                                #295
                                Hello i have a 8f8c -Latitud 7400 and reader CH341A any tutorial to read dump please ?
                                • anshad
                                  • Nov 2010
                                  • 249
                                  #296
                                  There are plenty of demo videos available in the Youtube.
                                  https://www.youtube.com/watch?v=4qX2zihB6UE
                                  If you haven't purchased the programmer yet, i would highly recommend the upgraded version which has proper volt setting is available. Older black PCB one is not that reliable and need a hardware mode to make it compatible with some chips.
                                  https://www.youtube.com/watch?v=7_mnuuXyPiI
                                  In my experience, CH341A is a very reliable SPI programmer. What gave it a bad reputation is the usual way of using a clip to read the chip on board. This is a very unreliable method with any SPI programmer - even with costly programmers, reading and writing with the clip is a headache.. If you have good soldering skill, desoldering the chip and use a compatible SPI adapter is the best way. Otherwise you can try with the clip. In any case, you should read the chip multiple times and verify the checksum of all.
                                  • CammyTier1
                                    Tier 1 Assets
                                    • May 2022
                                    • 43
                                    Could someone please remove pass for me thanks in advance
                                    • hoaca388
                                      Badcaps
                                      • Jan 2022
                                      • 12441
                                      #298
                                      Removed
                                      ​https://www.badcaps.net/donate
                                      • CammyTier1
                                        Tier 1 Assets
                                        • May 2022
                                        • 43
                                        Originally posted by hoaca388
                                        Removed
                                        Thanks mate any chance u could explain what u do to unlock them i have like 10 - 15 off them that i will need to do after i replaced screens on them
                                        • biosedit
                                          • Sep 2018
                                          • 60
                                          • Pakistan
                                          #300
                                          please remove password from dump
                                          e7400
                                          • Godfather79
                                            Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                            by Godfather79
                                            Hello everyone in the community
                                            Dear Sir,
                                            I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                            Problem details:
                                            * Model: Dell Latitude 5520.
                                            * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                            * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                            * Service Tag: (Enter your actual Service Tag from the laptop here)
                                            * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                            11-08-2025, 10:04 AM
                                          • Godfather79
                                            by Godfather79
                                            Dear Sir,
                                            I need help removing/unlocking the BIOS password on my Dell Latitude 5520 laptop.
                                            Problem details:
                                            * Service Tag: (HMHJQ93)
                                            What I need:
                                            Please help me generate a Master Code for the 3FE2 password based on my Service Tag, or for a "Virgin" (completely clean) BIN file without a password for this model.
                                            In the attachment...
                                            Today, 07:18 PM
                                          • berrylinx
                                            Dell Latitude 7400 2-in-1 bios with absolute persistence lock
                                            by berrylinx
                                            Dell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
                                            Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
                                            Thank You....
                                            09-15-2025, 03:02 PM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                            11-02-2024, 04:19 AM
