Dell Latitude 7400 Bios Password
  • welcometoo
    • 17
    • morocco
    #101
    Re: Dell Latitude 7400 Bios Password 8FC8 Suffix
    read about uefitool , me region , hex editing
    if i have time i will make a video to explain the process and post the link here
    • massimmi
      • Jan 2021
      • usa
      #102
      Thanks very much @Imranromi. Complete noob here so bare with me. How do I send the bios file? Would I need to get into the machine for that? How do you PM on here? Do I have the ability to do that as a new user?
      • imranromi
        • Jan 2015
        • 1292
        • Pakistan
        #103
        You need programmer read bios chip and post here.If you know soldering then easy for you..
        • massimmi
          • Jan 2021
          • usa
          #104
          @Imranromi Is this what you need? F72DP73-8FC8. Let me know. Thanks very much.
          • imranromi
            • Jan 2015
            • 1292
            • Pakistan
            #105
            This suffix not possible to generate Master code.If you want unlock you need read bios chip find in motherboard or need bios programmer.
            • tarek5313
              • Mar 2015
              • 31
              #106
              Originally posted by Karol
              Before you buy CH341A, Take a look on what chip you have to read/write.
              Then go to software programmer and look if that chip is supported.
              And one more thing. You will be surprised when you discover that CH341A have 5V on data lines (pin 1, pin 2).
              I recommend RevelprogIS.
              it can be cnfigured to drive at 3.3v and even 1.8v, there is nothing wrong with CH341
              • islul
                • Feb 2021
                It's been a few months I was wondering if anyone was able to find something?
                • zombieramones
                  • Feb 2021
                  • U.S.A.
                  #108
                  i am desperatly trying to figure out a way to unlock my bios, i bought my laptop off facebook and got scammed and i cannot recover the os until i get my bios password the system number is 7ZVQ433-8FC8
                  • zombieramones
                    • Feb 2021
                    • U.S.A.
                    #109
                    • sirko33
                      • Feb 2021
                      • Lvovskiu
                      #110
                      Who can help? Dell 7400 bios password. I will take a dump in the near future. Respond!
                      • derekbez
                        • Feb 2021
                        #111
                        Greetings @imranromi, @karol and the many others that have provided such good info on this thread. It has been most useful and appreciated.
                        Please will you help me with this Dell 7400 bios.
                        The locked bios screen show this code: FTZ3YY2-8FC8
                        The BIN dump is attached.
                        • derekbez
                          • Feb 2021
                          #112
                          @zombieramones and @sirko33 - as I'm sure you know from your research on the topic, the bios password on the Dell 7400 can only be reset by physically handling the specific BIOS chip on the laptop's motherboard. You will need to extract the current bios using a flash programmer, and post that dump here. Hopefully, if you ask nicely, one of the kind people who are more knowledgeable than us on this forum will be able to give you a fresh bios (without a pw), which can then be written back to the bios chip on the laptops motherboard.
                          • sirko33
                            • Feb 2021
                            • Lvovskiu
                            #113
                            I know. It is simply unknown whether the one who will be able to redo the dump remains.
                            • peste
                              • 13924
                              • ROMANIA
                              #114
                              the password bios has 32MB, not 1MB..look for the chip that has the 32MB bios on the motherboard, make a backup, check it with the HxD program to be ok, and write this bios on the 32MB chip, the 1MB bios which you posted don't go to it..if it doesn't work post the backup of the 33MB bios ..
                              • derekbez
                                • Feb 2021
                                #115
                                Thanks @peste. So far I can only find two chips that look like they are BIOS chips. 25Q80DV and 25Q80C. Both are quite close to where the SSD plugs in.
                                Please could you advise where on the board I might find the correct chip? Thanks
                                • sirko33
                                  • Feb 2021
                                  • Lvovskiu
                                  #116
                                  Look for the UC5 chip, it is on the other side of the board. Marking 25B256
                                  • cobrakill
                                    • Jan 2021
                                    • France
                                    #117
                                    thank you shiro for this indication I was looking for the chipset for a while. Do you have a solution to connect to it because it is not the same format as 25Q80DV and 25Q80C?
                                    • GRaviation
                                      • Feb 2021
                                      #118
                                      Hi there,
                                      I have a Dell LAtitude 7400 2TF11Z2-8FC8 i have managed to read the bios and created a bin file with the dump. can someone help please?
                                      I have attached the bios dump, can anyone remove the passowrd ?
                                      I am completely new to this and went through youtube videos bought a c431a programmer and after 3hours managed to finally read the chips. I have a winbond and gigadev bios chip both are on the file.
                                      Would really appeciate if anyone could help, i have been trying to get this sorted for over a year now and cant find any IT technician that is willing to help.
                                      Thanks !
                                      G
                                      • GRaviation
                                        • Feb 2021
                                        #119
                                        Have you been able to figure out how to read the bios chip in the #uc5 position? as the format is different and the clip will not read it. the other bin files for chips 25Q80DV and 25Q80C are only 1mb so maybe i can assume these are not the ones?
                                        • GRaviation
                                          • Feb 2021
                                          #120
                                          Hi were you able to read the chip marking 25B256? the clip does not fit as the size is different. does anyone have a solution?
                                          • Godfather79
                                            Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15) bios
                                            by Godfather79
                                            Hello everyone in the community
                                            Dear Sir,
                                            I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                            Problem details:
                                            * Model: Dell Latitude 5520.
                                            * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                            * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                            * Service Tag: (Enter your actual Service Tag from the laptop here)
                                            * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                            11-08-2025, 10:04 AM
                                          • Godfather79
                                            by Godfather79
                                            Dear Sir,
                                            I need help removing/unlocking the BIOS password on my Dell Latitude 5520 laptop.
                                            Problem details:
                                            * Service Tag: (HMHJQ93)
                                            What I need:
                                            Please help me generate a Master Code for the 3FE2 password based on my Service Tag, or for a "Virgin" (completely clean) BIN file without a password for this model.
                                            In the attachment...
                                            Yesterday, 07:18 PM
                                          • berrylinx
                                            Dell Latitude 7400 2-in-1 bios with absolute persistence lock
                                            by berrylinx
                                            Dell Latitude 7400 2-in-1 bios with absolute persistence lock, Service Tag: HRPJN53
                                            Can someone please assist with this please. I've provided two dump files using Xgeco T48, one is the read and default saved and other is the Flash saved option, they're labeled according.
                                            Thank You....
                                            09-15-2025, 03:02 PM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • jhanra
                                            by jhanra
                                            in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, πŸ˜…πŸ˜…πŸ˜…...
                                            11-02-2024, 04:19 AM
