BIOS Dell XPS 15-9575 LA-F211P
  • Zaraki7777
    • Sep 2017
    • 174
    Any one help me for bios (clean me).
    Thanks in Advanced
  • Zaraki7777
    • Sep 2017
    • 174
    Re: BIOS Dell XPS 15-9575 LA-F211P
    Hellllo, any one
    • peste
      • Dec 2016
      • 13924
      • ROMANIA
      try...
      • Zaraki7777
        • Sep 2017
        • 174
        Thank you i will try it
        • Zaraki7777
          • Sep 2017
          • 174
          Does not work
          • peste
            • Dec 2016
            • 13924
            • ROMANIA
            Try this...
            • Zaraki7777
              • Sep 2017
              • 174
              Thank you, I will test it
              • Zaraki7777
                • Sep 2017
                • 174
                Sorry, but it does not work.
                  • 22286
                  Try this bios .
                  • Zaraki7777
                    • Sep 2017
                    • 174
                    Thank you so much, i will try it.
                    • pooya_pm
                      • Jan 2021
                      • 259
                      • iraq
                      Bios worked?
                      • Zaraki7777
                        • Sep 2017
                        • 174
                        works, thank you
                        • beast4ever
                          • Feb 2015
                          • 174
                          • egypt
                          Hello friends
                          I want to fix the file not working
                          Power​
                          st : 67ns5q2
                          ex : 13523902202
                          DAZ10 LA-F211P REV 1.0(A00) 2018-01-05
                            SMDFlea commented
                            Editing a comment
                            try the bios at post 9
                        • beast4ever
                          • Feb 2015
                          • 174
                          • egypt
                          Originally posted by beast4ever
                          Hello friends
                          Power
                          st : 67ns5q2
                          ex : 13523902202
                          It didn't work. at post 9
                          • zenius
                            by zenius
                            12-08-2024, 06:13 AM
                          • mikeybass
                            by mikeybass
                            04-23-2025, 04:30 PM
                          • capoplays
                            Help with BIOS update on Dell G15 5515 after chip replacement
                            by capoplays
                            Hey everyone,
                            I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                            The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                            When I check the BIOS using the F12 menu Flash...
                            10-24-2025, 06:53 AM
                          • Akhlz001
                            by Akhlz001
                            09-20-2025, 07:15 PM
                          • Sathsul
                            Dell Latitude 5431 issues with dumping bios
                            by Sathsul
                            So, i kinda spend significant ammount of the last couple of days trying to flash a new bios, and or unlocking the current bios password with little to no results.
                            The whole thing started with it being the 8fc8 bios, i found the tools to unlock that but i needed a bios dump. So i pursued that, im at a point where i dessoudered the chip, and succesfully soudered it to the ch341, dumped whatever was on it.
                            However, the tools supposed to unlock the 8fc8 say that there is no 8fc8 hex inside. And when i followed diffrent tutorials to just flash a new bios onto the chip i got stuck on the...
                            10-28-2025, 07:49 AM
