Lenovo Unlock Dxe Driver Bios Collection
This topic is closed.
  • Sjenja
    • Jun 2016
    • 10
    • GoingDownTHeDrainCountry
    #41
    Re: Lenovo Unlock Dxe Driver Bios Collection
    L560 bios patched will work on other machines. No key needed.
    • Andreasbest
      • Aug 2014
      • 1196
      • Hellas ( Greece )
      #42
      How do i use the patche attached in first post?
      I just write it in winbond and follow the procedure:
      Remove all battery and CMOS battery
      press F1 to enter setup: password 1234
      wait 20sec or more.
      Enter any ID to hardware Id.
      Press 2x space bar when asked.
      Turn off the computer.
      and restore your original bios .
      • contact_laptop
        • May 2020
        • France
        #43
        Hi everybody,
        New on this forum and french : sorry for my english.
        I've tried to remove a svp password and computrace from a factory X240 that I bought (motherboard VIUX1 NM A091 Rev. 1.0).
        After flashing with patch, no result : when I plugged the AC, the power-on button lights 3 times then the X240 runs automatically but no beeps, no logo, ... I only hear the fan and the screen stays black even if the laptop stays plugged a long time.
        Any idéa, issue to fix it ? Is there an X240 patch available ?
        Thanks for reply and best regards
          • 31255
          if the laptop has a switch on the base/cover you need to keep it pressed.
          • contact_laptop
            • May 2020
            • France
            #45
            STJ,
            Thanks for your reply (#47) at my question (#46) : I've pressed a long time the switch on the base cover (little hole near the external battery) without anything plugged (no ac adapter, no battery [ext/int/cmos]) but result is the same.
            Any idéea ?
            Thanks for your answer and best regards
            • Andreasbest
              • Aug 2014
              • 1196
              • Hellas ( Greece )
              #46
              Sorry but my english aren't so good so i have a noob question.
              When i try to enter bios i get the screen in attachment.
              The procedure on this thread to unlock DXE driver will remove it??
              • aleksandaralex
                • Jan 2016
                • 10
                • Serbia&Montenegro
                #47
                yes, if you make a patched bios and go through the procedure
                https://www.badcaps.net/forum/showpo...72&postcount=1
                • Andreasbest
                  • Aug 2014
                  • 1196
                  • Hellas ( Greece )
                  #48
                  So i just backup my original dump
                  i store it
                  then i write the patched T440 that is available in the post that you show me
                  i follow the procedure
                  and BIOS password is gone forever?
                  • aleksandaralex
                    • Jan 2016
                    • 10
                    • Serbia&Montenegro
                    #49
                    i store it
                    send the bios here, someone will already patch it for you...
                    I don't believe it will go with the bios from post #1.
                      • 21922
                      The OP at post #1 requested that only patched working files are posted in this thread
                      Quote:
                      Please,you can add your file patched and model version for add to the collection.
                      Thanks to add patch only OK.
                      For a password release request, please use the other page. https://www.badcaps.net/forum/showthread.php?t=65996
                      You can post your patch here, if only this one worked !!
                      • RethoricalCheese
                        • Mar 2013
                        • 1519
                        • Estonia
                        #51
                        Originally posted by contact_laptop
                        STJ,
                        Any idéea ?
                        That's the wrong switch. Black switch, not white.
                        • Andreasbest
                          • Aug 2014
                          • 1196
                          • Hellas ( Greece )
                          #52
                          So the files from #1 post (Lenovo T440 in my case) will work in both T440 that i got, right?
                          • aleksandaralex
                            • Jan 2016
                            • 10
                            • Serbia&Montenegro
                            #53
                            NO Bro,
                            not worked,
                            pls post your t440 bios dump on this thread:
                            • Andreasbest
                              • Aug 2014
                              • 1196
                              • Hellas ( Greece )
                              #54
                              I try in T440.
                              Flashed the patched file but screen remains black, only power led on
                              I put some adhesive tape in bottom switch,
                              • dihcar84
                                • Aug 2012
                                • 201
                                • morocco
                                #55
                                thank you sooooo mutch
                                • xmasterboss
                                  • Apr 2014
                                  • 34
                                  #56
                                  No. Bought new TL866 II Plus to read 256MB BIOS. If someone can inject patch, i can post BIOS here.
                                  • Andreasbest
                                    • Aug 2014
                                    • 1196
                                    • Hellas ( Greece )
                                    #57
                                    You can buy the DXE patch from here https://www.allservice.ro/forum/viewtopic.php?t=3044 (80$) and then post it here to patch it and make it work in all T490. Plus you help the community
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1519
                                      • Estonia
                                      #58
                                      Looks like not possible right now : D Only available in their service store.
                                      • Andreasbest
                                        • Aug 2014
                                        • 1196
                                        • Hellas ( Greece )
                                        #59
                                        Do they mean exclusively OR laptop must be sent in their store?
                                        • RethoricalCheese
                                          • Mar 2013
                                          • 1519
                                          • Estonia
                                          #60
                                          Looks like temporarily available only in their store. So it might be available remotely at a later time.
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
