Lenovo Unlock Dxe Driver Bios Collection
This topic is closed.
    • 21922
    Re: Lenovo Unlock Dxe Driver Bios Collection
    Originally posted by Smartguru@24
    How to creat patch file sir?
    Info in another thread. https://www.badcaps.net/forum/showthread.php?t=87588
    This thread for patched versions only
    • volinakis
      • Jan 2021
      • 2874
      • N/A
      #102
      Worked just fine on T440p, thank you!
      My method: I took another 25Q32 chipset and wrote the patched file with CH341A programmer - I didn't "touch" the original chipset, read erase or write - I followed the steps described, after all was done I replaced the chipset with original one and restored factory settings in BIOS. No beeps, no errors except when I turned on 1st time with original chipset I had a checksum error fixed by updating bios with last version.
      Thank you again, great job!
      • kaskader
        • Apr 2021
        • Poland
        #103
        Thanks very helpfull. I did for x250 but the file you uploaded didnt work for me.
        • Mazorca
          • Jan 2017
          • 463
          I like volinakis method if more than one need to be fixed. Bios chips are cheap compared to whole boards, plus it cuts down on the heat/reheat again cycles. Heck, I will order a few just to have them handy.
          • volinakis
            • Jan 2021
            • 2874
            • N/A
            #105
            I did it this way because I saw - reading messages on this forum - others had problems writing back the original file, I think because of the programmer reading with errors. I advice whose who use the original chipset to clean the terminals with technical alcohol, also the adapter.
              • 21922
              Originally posted by ednar88
              I need an unlocked BIOS file patch for lenovo T440s 25q64
              Please read post #101 ,this thread for patched versions only.
              • Lornet
                • Mar 2021
                • 27
                • France
                #107
                Originally posted by ggrn
                Im getting 2x 5 beeps and then shutdown too
                The patched bios for X250 works but I think that you'll have problem if the ME Firmware version of your original bios and the patched one aren't the same. I have had trouble too and resolved it by using Intel Easy Clean Me tool for the ME firmware version being equal for each bios.
                • alihomee
                  • Dec 2012
                  • 1594
                  • malaysia
                  #108
                  i tried patch file for x250 but does not work can get any help....ori file is attach
                    • 21922
                    This thread is for patched versions only, please read the first post. Some of the patches at post #1 require the ME region to be cleaned.They do work. The autopatcher works too, all you have to do is install python,then drag and drop, its not difficult.
                    • digitecelettronica
                      • Sep 2019
                      • Italia
                      #110
                      Looking for patched/Unlocked Lenovo P50 20EQ, can anybody help?
                        • 21922
                        • mylocky
                          • Jun 2014
                          • 18
                          • hungary
                          #112
                          Thank you!!!! You are awesome!
                          +1 working on my T440p, without modify MEC.
                          • HARAN963
                            • Mar 2021
                            • 45
                            • FRANCE
                            #113
                            Pls
                              • 21922
                              Originally posted by HARAN963
                              Pls
                              Read post #111 ,this thread is for patched versions ONLY !
                              • volinakis
                                • Jan 2021
                                • 2874
                                • N/A
                                #115
                                Patched file for X270 didn't work for me, failed after asked for key for hardware id. (invalid key) I took a patched file from https://www.badcaps.net/forum/showth...highlight=X270
                                and worked.
                                • sattaraq
                                  • Jan 2020
                                  • 5
                                  Hello Maxpower
                                  if you have a patch for thinkpad yoga x1 4th Generation
                                  regards
                                  • Maxpower3
                                    Bad Veteran
                                    • Feb 2018
                                    • 1355
                                    • France
                                    #117
                                    Originally posted by sattaraq
                                    Hello Maxpower
                                    regards
                                    32mo Bios not patch for this model
                                    • rassystems
                                      #118
                                      lenovo x1 carbon 2nt gen password reset.help
                                      thank you....
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1355
                                        • France
                                        #119
                                        thank you....
                                        look if 24rf08 or mec
                                          • 21922
                                          thank you....
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
