Bios read help fot HP 830 G5
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1356
    • France
    I would need help for reading a bios on 830 G5 .
    No desire to retire the chip and I tested with wires on TL866II
    but I can’t read it . this is a MX25L25673G
    It’s not recognized by the programmer.
    Chip id not correct and Full FFFF in read .
    I took the advice here with the charger but no better.
    https://www.badcaps.net/forum/showthread.php?t=79911
    He didn’t make it.
    An idea, an advice please
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: Bios read help fot HP 830 G5
    I don't think 256Mb chips are supported by that programmer.
    I used raspberry pi + latest flashrom for that size.
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1356
      • France
      i desolder and read with clip .
      but chip id is always wrong .
      read is not full ff.
      somebody confirm the read is ok ?
      you can confirm that the HPUnlocker software works with 830 g5 ?? Please
        • 21993
        The MX25L25673G is in the support list. I have the older tl866cs ,i get errors like that when a chip isn`t seated properly in the adapter or zif socket.
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1356
          • France
          Ok, this is the clip that falsely reads, I solder directly
          This is why, you must always control its reading.
          I really don't like the eprom clamp
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1356
            • France
            It's good,problem solved
              • 21993
              What sort of clip do you have,a cheap one or a pomona.Its always more reliable desoldering the bios
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1356
                • France
                3M clip but I'm thinking of a Chinese clone
                • gsmkings
                  • Jul 2020
                  • 11
                  Hello , how did you get this resolved , I have the same setup but having issues reading the same chip ,
                  Tl866+
                  MX25L25673G
                  • jagiro84
                    • Jan 2020
                    • 41
                    • Netherlands
                    Sadly no response on how he solved it
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1356
                      • France
                      the chip was soldered directly to a programmer support, I no longer use the clamp
                      • jagiro84
                        • Jan 2020
                        • 41
                        • Netherlands
                        Like this?
                        I am receiving error with ny tl866 with check id on
                        • see1001
                          see1001 commented
                          Editing a comment
                          your device is old.does not recognize eprom. your device tl 866cs. 866+or above for MX25L25673G
                      • Bloodhoundje
                        by Bloodhoundje
                        03-16-2024, 03:12 PM
                      • macabook
                        by macabook
                        🧩 Initial Issue
                        07-24-2025, 02:17 PM
                        by Vesko356
                        08-11-2023, 03:27 AM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
