try this
Asus zenbook UX305FA bios
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
Channel: BIOS Requests ONLY!
by grimacelordHello,
Anyway, I took dumps of both chips and then downloaded the latest update for this motherboard from ASUS's website...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
by jbonavitaHi, my laptop wont boot at all
Some issues
Things I tried
1- Update / clear ME: Took the non working bios, made a backup, and did this: https://www.badcaps.net/forum/troubl...theory/trouble...-
by throwaway327ASUS ROG Ally X - (Handheld Gaming PC)
Model No: RC72LA
Serial No: SBNVKD001014459
I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...-
- Loading...
