Need Panasonic FZ-G1R (mk4) Bios DHLB1030ZD/X1
  • outsider
    • Apr 2014
    • 104
    • localhost
    Hi Friends
    I need unlocked bios dump of Panasonic FZ-G1.
    MB: DHLB1030ZD/X1(1)
    BIOS: MX25L12873F
    This original dump file.
    Thanks!
      SMDFlea commented
      Editing a comment
      Post moved to DHLB1030ZD/X1 topic.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12272
    Originally posted by outsider
    Hi Friends
    BIOS: MX25L12873F
    Thanks!
    Unlocked
    • outsider
      • Apr 2014
      • 104
      • localhost
      Originally posted by hoaca388
      Unlocked
      Works great! Thank You very much!!!
      • AquaMan Ua
        by AquaMan Ua
        05-17-2025, 09:40 AM
      • aa10aa10
        Panasonic Toughbook CF-33 mk1 BIOS repair
        by aa10aa10
        Good day,
        I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
        I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
        01-21-2025, 06:13 AM
      • macabook
        by macabook
        🧩 Initial Issue
        07-24-2025, 02:17 PM
      • Vesko356
        by Vesko356
        08-11-2023, 03:27 AM
      • James Jackson
        Panasonic CF-20G0247VM BIOS Bad Flash Help
        by James Jackson
        I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
        Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
        05-01-2025, 11:28 AM
