HP Probook 470 G0 bios dump please
  • alexKZ1010
    • Nov 2019
    • g
    people help really need to ask thanks
    Hey. if you have a dump from the HP 470 G0 BIOS. I can not find
    • 21665
    Re: HP Probook 470 G0 bios dump please
    Post your bios backup here .
    • livermor2003
      • Russian
      Works Dump HP 740 G0.Pog:TL866 II Plus.
      • EthanMai
        • Jul 2020
        • 103
        • 美国
        THANKS!
        • eukal
          • Jul 2012
          • 43
          • belgique
          Hello could you help me to unlock bios password on Hp probook 470 g0.
          I have try with hp unlocker and succesfully write the new bios but not working.
          Here is the orginal file and the file that suppose to be unlock by hp unlocker.
          Thanks.
          • peste
            peste commented
            Editing a comment
            post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
        • peste
          • 13422
          • ROMANIA
          Thanks.
          post S/N, full name and model, motherboard model, product number etc.
          • eukal
            • Jul 2012
            • 43
            • belgique
            Hello ok thanks. I see your post to use openned case for asking bios i note it for the next time , i was thinking it's notrmal to make another post sorry.
            Here is the info :
            HP ProBook 470 G0
            Serial : 2CE3411LYC
            Product : H0W68EA#UUG
            Motherboard Model : 721521-601
            Thanks​
            • eukal
              • Jul 2012
              • 43
              • belgique
              Hello have you seen my answer ? Thanks
              • peste
                • 13422
                • ROMANIA
                try..
                • abouahmed
                  • Apr 2015
                  • maroc
                  Thank you very much​
                  • torgbui
                    • Oct 2021
                    • Ghana
                    Try this file. The Probook 470 G0 and 450 G0 use the same bin file. I've tried and it worked.
                    • Ahari
                      by Ahari
                      I...
                      08-13-2025, 06:12 AM
                    • grimacelord
                      Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                      by grimacelord
                      This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                      Motherboard model number: DA0PAMB46A1 REV: A
                      Secondary motherboard model number: 0PAB
                      SKU: 685K4UA
                      Serial number is: 5CD3223BJP
                      Recently reflashed this laptop with latest BIOS and once...
                      05-07-2024, 08:06 AM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • studdy05
                      Bricked HP Probook 450 G7 Bios questions
                      by studdy05
                      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                      Ive got...
                      07-08-2025, 09:24 PM
                    • haitham sharabati
                      by haitham sharabati
                      Hello engineers 😀,
                      🔧 Device Info:
                      - Model: HP 15-da2007ne
                      - Product Number: 8XF55EA#ABV
                      - Serial Number: CND0338P0D
                      - CPU: Intel Celeron N4000
                      💀 Problem:😅
                      08-07-2025, 04:54 AM
