HP i xxxxxxxx bios password,System Disabled, 8-digit code Unlock
Every donation made will go towards server fees and maintenance costs.Comment
Re: HP i xxxxxxxx bios password,System Disabled, 8-digit code Unlock
Need help!!
Hp envy
System disabled code:
i 50898592
Thank u so much!!Comment
see https://docs.google.com/spreadsheets...it?usp=sharingComment
hp 15 pavalion
Error code is [i 51006785]
Thanks in advanceComment
Channel: BIOS Requests ONLY!
by BloodhoundjeHi everyone,
I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
I have desoldered the bios chip (GigaDevice...-
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
- Loading...
