Fujitsu-Siemens bios unlock tool
Here is the newest cypher
Let's make another try...
Generate another code ( DO NOT SHUT DOWN OR RESTART THE LAPTOP) and publish here...I will try to generate a master pass for you...
For your codes I have these unlock codes, eventually check if corresponds with yours...
2844-0112-1720-4663-9308 - lc2vfcpj OR 9546543
2939-5099-3731-5060-2382 - 9n2f70pk OR 9155935
3100-1104-3317-1700-3276 - 7uinqcp4 OR 8743232
2486-0116-6529-4903-9372
Issue is I wont be able to get to the password prompt without restartingLeave a comment:
3100-1104-3317-1700-3276 - 7uinqcp4 OR 8743232Leave a comment:
I already tried this three times as well
I'm thinking it has something to do with the Master codes changingLeave a comment:
https://beta.bios-pw.org/I have a Fujitsu lifebook l1010 and I'm having issues unlocking it.
So far I've gotte 3 cyphers for the master password.
My issue is that after I get the system is disabled message I have to power it off as nothing works and there is no battery.
After power off I hit f2 and am presented with the password screen
when I enter the decryted master password though it's invalidLeave a comment:
Hello, this is a Fujitsu (now Kontron brand) motherboard, model is D3633-S12, S/N 57608589 (there are other numbers spread all over the board, but I guess this is the S/N).
The password area within the dump should be:
BC 67 55 A4 38 C7 65 92 A8 DD CB DC 73 88 CC F3 86 08 10 F0 78 93 2B E9 68 F5 74 12 C1 F4 A2 D4
Thank you!Leave a comment:
Hello, I am stuck with a Fujitsu industrial motherboard model D3633 and I need to gain access to UEFI settings. Any help on getting a password without clearing all settings will be appreciated.
Hi everybody.
Could some one help me.
fujitsu lifebook e559
203c-d001-942d-8c67-7932-2b4a
Thank you in advanceLeave a comment:
The bios file is incorrect.
I will correct it and attach it.Attached FilesLeave a comment:
Hi there,
i need help unlocking a Lifebook
Fujitsu Lifebook U9310X/D FMVU29013
i7-10610U
Motherboad Model FJNB2DB A2
serial R0800592
After entering 3 incorrect passwords, a message appears - the system is disabled. and there is no hash key
Good day
I need help
Fujitsu lifebook s series Model: e5412
3hqgo3
jqw534
0qww294e
no hash code. What can i do?Leave a comment:
Good day
I need your help again
Fujitsu lifebook s series Model: s751
3hqgo3
jqw534
0qww294e
hash code 0222-3746-6157-1759-3902-0451
if you can, please helpLeave a comment:
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by macabookHello everyone,
🧩 Initial Issue- Board powers on (fans spin, keyboard lights up and can be adjusted, caps lock led lights), but no display or backlight
- External display (HDMI) shows
07-24-2025, 02:17 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
by piratiHello everyone,
I decided to try flashing a new BIOS, but since I didn’t want to desolder...-
- Loading...
