Fujitsu-Siemens bios unlock tool
  • hamza hamza
    • May 2022
    • 28
    • morocco
    #541
    Hi everybody.
    Could some one help me.
    fujitsu lifebook e559
    203c-d001-942d-8c67-7932-2b4a
    Thank you in advance​
    • alocam
      • Oct 2015
      • 6
      • Argentina
      #542
      Hello, I am stuck with a Fujitsu industrial motherboard model D3633 and I need to gain access to UEFI settings. Any help on getting a password without clearing all settings will be appreciated.
      Thank you!
      • peste
        • Dec 2016
        • 13335
        • ROMANIA
        #543
        Thank you!
        post the full name and model, S/N, hash code...
        • alocam
          • Oct 2015
          • 6
          • Argentina
          #544
          Hello, this is a Fujitsu (now Kontron brand) motherboard, model is D3633-S12, S/N 57608589 (there are other numbers spread all over the board, but I guess this is the S/N).
          The password area within the dump should be:
          BC 67 55 A4 38 C7 65 92 A8 DD CB DC 73 88 CC F3 86 08 10 F0 78 93 2B E9 68 F5 74 12 C1 F4 A2 D4
          Thank you!
          • Aleytia Fairlight
            • May 2025
            • 6
            • Philippines
            #545
            I have a Fujitsu lifebook l1010 and I'm having issues unlocking it.
            So far I've gotte 3 cyphers for the master password.
            2844-0112-1720-4663-9308
            2939-5099-3731-5060-2382
            3100-1104-3317-1700-3276​
            My issue is that after I get the system is disabled message I have to power it off as nothing works and there is no battery.
            After power off I hit f2 and am presented with the password screen
            when I enter the decryted master password though it's invalid
            • hamza hamza
              • May 2022
              • 28
              • morocco
              #546
              https://beta.bios-pw.org/
              • Aleytia Fairlight
                • May 2025
                • 6
                • Philippines
                #547
                Originally posted by hamza hamza
                I already tried this three times as well
                I'm thinking it has something to do with the Master codes changing
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12237
                  #548
                  Hi everybody.
                  72b24d0e
                  • Stefan Steff
                    • Mar 2024
                    • 327
                    • Romania
                    #549
                    Let's make another try...
                    Generate another code ( DO NOT SHUT DOWN OR RESTART THE LAPTOP) and publish here...I will try to generate a master pass for you...
                    For your codes I have these unlock codes, eventually check if corresponds with yours...
                    2844-0112-1720-4663-9308 - lc2vfcpj OR 9546543
                    2939-5099-3731-5060-2382 - 9n2f70pk OR 9155935
                    3100-1104-3317-1700-3276​ - 7uinqcp4 OR 8743232
                    • Aleytia Fairlight
                      • May 2025
                      • 6
                      • Philippines
                      #550
                      3100-1104-3317-1700-3276 - 7uinqcp4 OR 8743232
                      Here is the newest cypher
                      2486-0116-6529-4903-9372
                      Issue is I wont be able to get to the password prompt without restarting
                      • Stefan Steff
                        • Mar 2024
                        • 327
                        • Romania
                        #551
                        Try this codes: ls23n0p8 OR 9440443
                        These are valid until next restart.
                        • Aleytia Fairlight
                          • May 2025
                          • 6
                          • Philippines
                          #552
                          did not work. I'm not sure why
                          • Stefan Steff
                            • Mar 2024
                            • 327
                            • Romania
                            #553
                            The code is for English QWERTY keyboard layout...maybe yours is different...
                            Write here if you need another code.
                            • Aleytia Fairlight
                              • May 2025
                              • 6
                              • Philippines
                              #554
                              I'm using a QWERTY keyboard leyout yes.
                              I think I need to just confirm a few things.
                              First is that in order to obtain the cypher I enter the three passwords which results in a system disabled message with the cypher.
                              Now after obtaining the master password. I think this is where I'm having issues.
                              in order to get back to the password prompt I need to power off the laptop as this is the only way I know to get out of the system disabled screen.
                              but I think it's this power on and power off sequence that's causing issues as it resets the cypher and thus the password doe not work.
                              Is there a way to get out of the system disabled screen withut powering the laptop off?
                              • Stefan Steff
                                • Mar 2024
                                • 327
                                • Romania
                                #555
                                You do all right.
                                I use this method on a lot of FS laptops and worked fine.
                                After the three passwords I get the lock code.
                                Restart by power on button and input the unlock code.
                                Battery must be charged and the CMOS battery must have at least 3.0 V.
                                Good luck!
                                • Aleytia Fairlight
                                  • May 2025
                                  • 6
                                  • Philippines
                                  #556
                                  You do all right.
                                  Good luck!
                                  well there's my issue, can I get away with just the battery or plain old AC? or do I r4eally need to replace the CMOS?
                                  • Stefan Steff
                                    • Mar 2024
                                    • 327
                                    • Romania
                                    #557
                                    You need to replace the CMOS battery if its voltage is under 3V.
                                    • menshawy
                                      • Aug 2013
                                      • 400
                                      • egypt
                                      #558
                                      • Iti Deu
                                        Kriss
                                        • Apr 2025
                                        • 4
                                        • Polska
                                        #559
                                        Hi friend
                                        Supervisor password
                                        Fujitsu siemens e8310
                                        Serial YK8J120899
                                        • danito
                                          • Jun 2016
                                          • 1054
                                          • Romania
                                          #560
                                          Originally posted by Iti Deu
                                          Hi friend
                                          Supervisor password
                                          Serial YK8J120899
                                          When asked for a password, enter these:
                                          First password: 3hqgo3
                                          Second password: jqw534
                                          Third password: 0qww294e
                                          and generate spv here
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
