Hp probook 640 g1 bios
  • Dstecno
    • Jun 2019
    • 30
    • MΓ©xico
    #101
    Re: Hp probook 640 g1 uma
    Hello friends
    Need help with removing the BIOS Admin password. this HPUnlocker didn't work for me, or i didnt in the rihgt way, attached the original backup with password.
    mb 6050a2566302-mb-a03 14"
    • Dstecno
      • Jun 2019
      • 30
      • MΓ©xico
      #102
      hello friends, its solved, after trying a coupple times, the unlocker software works perfect!! i dont have password anymore
      • pingaroon
        • Nov 2019
        • 121
        • uk
        #103
        Hi, can anyone correct this corrupt bios from my machine? I am getting the fan on full speed after power on. Thanks!
          • 22293
          Have you tried cleaning the ME firmware https://www.badcaps.net/forum/showthread.php?t=88533
          • pingaroon
            • Nov 2019
            • 121
            • uk
            #105
            Hi, yes thanks - I have done that process before but in this case the ME version is 9.0.22.1467 and I can't find the flash image tool with the same revision. I've pawed over the archives on win-raid but it skips this version.
            Do you know where I can get it? Cheers.
              VIP Moderator
              • Aug 2018
              • 4386
              • Bulgaria πŸ‡§πŸ‡¬
              #106
              ...the ME version is 9.0.22.1467 and I can't find the flash image tool with the same revision...
              There is no need to search for the exact same version of FIT, you can use ME System Tools v9.1 r7 - (2018-09-01) - for systems running ME v9.0 - v9.1 posted in win-raid by plutomaniac.
              Become a Badcaps supporter
              Thanks to all supporters.​
              • pingaroon
                • Nov 2019
                • 121
                • uk
                #107
                ok good to know, thanks! I have just cleaned it using FIT 9.1
                I won't be able to test it till tomorrow, but when I scan the outimage file with MEanalyzer, it still says type "extracted", not "configured"? It shows the FIT version as 9.1 in the outimage file as it should, so why would it not say "configured" as the guide says it should? Thanks
                  VIP Moderator
                  • Aug 2018
                  • 4386
                  • Bulgaria πŸ‡§πŸ‡¬
                  #108
                  How about RTFM? You're looking for help, or for babysitter here? Don't want to be rude, but come on man - there is a beautiful guide, just take time to read it carefully!!! Want help - help yourself first.
                  Hint:
                  Originally posted by plutomaniac
                  Import the output file to ME Analyzer and check if the Major/Minor versions & SKU are the same as before. Also, make sure the Type is reported as "Extracted" which means that the inputted image is OEM/FITC configured. Whether the DATA section is now Configured and not Initialized cannot be checked/verified by ME Analyzer but if you followed the above steps properly you should not be having any issues.
                  • pingaroon
                    • Nov 2019
                    • 121
                    • uk
                    #109
                    Hint:
                    > 8. Open the bios with MEAnalyzer,it should say Configured
                    Jeepers, take the chill pill, and remember the adage "Assumptions make an ASS out of UME" lol. I've been reading the FM for 30 years and in the vast swathe of information out there, it's easy to miss a detail here and there, especially when you are into new territory and expanding knowledge into different areas. I see that section now in the detailed guide, so it's safe to say that point 8 above is what is known as a BUM STEER. But thanks, anyway
                    Cleaning the bios didn't make any difference. I got another bios from another machine and the same result with that, so it seems this board has other issues...
                      VIP Moderator
                      • Aug 2018
                      • 4386
                      • Bulgaria πŸ‡§πŸ‡¬
                      #110
                      ...I've been reading the FM for 30 years and in the vast swathe of information out there, it's easy to miss a detail here and there...
                      I got another bios from another machine and the same result ... I am getting the fan on full speed after power on.
                      Hmmm...Strange...Very Strange!
                        • 22293
                        Step 8 in my guide is only there if you`re following the video ,using the practice bios and FIT (from version 11 tools),my guide isn`t meant to cover everything . The win-raid guide is the one to follow, D3. ME 7 - 10 & TXE 1 - 2 .
                        Been reading the FM for 50+ years ,and still making mistakes
                        • Muhammad Hamid
                          • Jan 2019
                          • 9
                          • Pakistan
                          #112
                          Please Remove the Bios Admin password.
                          • qayyum786
                            • Aug 2018
                            • 1959
                            • INDIA
                            #113
                            Originally posted by muhammad hamid
                            please remove the bios admin password.
                            try
                            • Muhammad Hamid
                              • Jan 2019
                              • 9
                              • Pakistan
                              #114
                              It's working. Thank you so much..
                              God bless you..
                              Thank you again 💞😃😊
                              • techkevz
                                • Mar 2019
                                • 14
                                • philippines
                                #115
                                Originally posted by imranromi
                                here try and reply.
                                ty 100% working
                                • ramrk
                                  • Feb 2019
                                  • 155
                                  • India
                                  #116
                                  640 G1 Bios password remove request
                                  6050A2566302-MB-A04 old backup BIOS PASSWORD protected
                                  • peste
                                    • 13924
                                    • ROMANIA
                                    #117
                                    Re: 640 G1 Bios password remove request
                                    https://www.badcaps.net/forum/showthread.php?t=79956
                                    • liberator
                                      • Aug 2021
                                      #118
                                      Re: HP Probook ZBook 14
                                      I saw the files and they look fine to me, so looks like the subsequent update didn't go ok.
                                      Try reprogramming the chip again (with the unlocked file).
                                      I appreciate your input @Vesoko356.
                                      I programmed the chip, verified it, then read it and compared the file with the original unlocked file! No way that the programming was a problem. After re-soldering the chip the laptop booted, password unlocked and was 100% OK for 1 day including multiple reboots!
                                      In the absence of other ideas I will reprogram the chip again but I would like to avoid removing it again if possible because one of the tracks is starting to lift...
                                      Maybe the HP BIOS update stuffed it - although the update went OK and it worked directly afterwards.
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria πŸ‡§πŸ‡¬
                                        #119
                                        I was offered a BIOS update by the HP app
                                        Avoid using these crappy HP programs, in most cases they install various updates in the background with or without your consent, I guess that's what happened in your case as well.
                                        Тhere is nothing to lose anyway - the laptop doesn't start at the moment as far as I understand from your post, so you have no choice but to try reprogramming the chip again. If by any coincidence no hardware defect has occurred, the laptop should work again.
                                        • osymatech
                                          • Aug 2016
                                          • Nigeria
                                          #120
                                          Can u teach me how to edit bios files
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • tlindi
                                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                            by tlindi
                                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                            >Read BIOS guides, methods, resources and tools
                                            Ack
                                            >Try the method at BIOS guides, methods, resources and tools before requesting help
                                            Ack
                                            >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                            python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                            01-30-2025, 04:26 AM
                                          • Soumana Sanou
                                            β€œHP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                            by Soumana Sanou
                                            Hello,πŸ˜‡πŸ˜‡πŸ˜‡
                                            I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                            πŸ”§ Model: HP ProBook 11 G2
                                            πŸ“¦ Serial Number: 8CG72478MY
                                            πŸ†” UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                            πŸ”’ BIOS Status: Locked with password
                                            The laptop is no longer under warranty and HP refused to help me.
                                            I’m looking for a custom SMC.bin file.
                                            I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                            Thanks a lot for your help!πŸ™πŸ™πŸ™...
                                            06-17-2025, 04:04 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
