Hp probook 640 g1 bios
  • szakacsa195
    • Apr 2022
    • 47
    • Magyarország
    #261
    Originally posted by kalilinux25
    please try this and report
    Thanks! Finally I did not test it, since this dump does not cointains my motherboard specific data.
    • szakacsa195
      • Apr 2022
      • 47
      • Magyarország
      #262
      My final solution to repair bios and restore original motherboard specific data:
      1. program bios chip with dump from post 249 -> bios does not contans machine specific data
      2. after powering on the motherboard it gives some error messages like in post 250 about the missing data, however it is possible to launch Windows
      3. when Windows is up, apply BIOS Configuration Utility from post 254 in the following way:
      3.1 start CMD as admin and,
      3.2 use BiosConfigUtility.exe /get:"actual.txt" command to write all available tokens / variable into actual.txt file
      3.3 use BiosConfigUtility.exe /setvalue:"token from actual.txt","new value" command -> e.g. BiosConfigUtility.exe /setvalue:"SKU Number","G3K60EZ#AKC" will program G3K60EZ#AKC as SKU
      3.4 repeat step 3.3 until you set all required tokens.
      In my case theese were: Product Name, SKU Number, (ENTER) Feature Byte, (ENTER) Build ID, Serial Number, Product Family, System Board CT
      3.5 when finished use BiosConfigUtility.exe /setvalue:"Manufacturing Programming Mode","Lock" to lock your bios
      4. shut down Windows
      5. power up your machine and it should start without any warning
      Thanks everyone for your help!
      • steenwijk
        • May 2024
        • 5
        • steen
        #263
        Need compleet new bios file for this laptop.
        Have new chip purchased and will use CH341 programmer
        Old bios data is not available.
        I have read that a serial number must be entered in the new BIOS.
        Read a lot but it is not completely clear to me with Google translate.​
        How can I best approach this?
        Thanks,
        Marcel from the Netherlands
      • steenwijk
        • May 2024
        • 5
        • steen
        #264
        sorry here the s/n: 5CG43200RT
        • steenwijk
          • May 2024
          • 5
          • steen
          #265
          I've come a lot further.
          I use NbDmiFit-2.07
          I have entered the information that I think should be included
          But keeps giving 2 messages.
          1. Product family
          2. System board CT Number
          (I did fill this in)
          Who wants to help me on my way because I can't get any further now.
          I'm trying to add photos.
          Thank you in advance
          Part config file:
          BIOSConfig 1.0
          ; Originally created by BIOS Configuration Utility
          ; Version: 4.0.32.1
          ; Date="2024/05/02" Time="04:22:03" UTC="2"
          ; Found 226 settings
          Manufacturer
          Hewlett-Packard
          Product Name
          HP Probook 640 G1
          System Board ID
          1993
          Product Family
          HP Probook 640 G1
          SKU Number
          A3009DD10203
          Notebook Model
          D9R53AV
          System Board CT Number
          PEBGU00WD7A5RWCZI
          Serial Number
          5CG43200RT
          Product Number
          D9R53AV
          Universally Unique Identifier (UUID)
          FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
          Processor Type
          Intel(R) Core(TM) i5-4200M CPU
          SKU Number
          H5G68EA#ABH
          Warranty Start Date
          00/00/0000
          Processor Speed
          2.50GHz
          Sunday
          *Disable
          Enable
          Monday
          *Disable​
          • steenwijk
            • May 2024
            • 5
            • steen
            #266
            Laptop is ready again.
            I didn't know exactly what to fill in because there were no labels attached.
            After a very long search on how to build the config file, we succeeded.
            Data from other 640 g1 uses a mix. haha
            Still missing a SKU number but found it.
            The config of the bios was very easy to adjust and fill in the missing data in "MPM TOOL" for Windows!!
            You read the current config in Windows and after editing you write it back.
            Finished!
            Put the working text file into youre bios chip.
            Maybe adjust
            No more annoying error messages at startup
            Hopefully this will also help other people now.
            Good Luck!
            Appendix:
            MPM tool
            Working bios file
            • matyka
              • Jan 2015
              • 179
              • Uk
              #267
              HP Probook 640 G1 BIOS Need
              Model: HP Probook 640 G1
              Serial: 5CG54674LJ
              PCID: A3009DD10303
              Product: F1Q66ET>ABU
              Need bios. Please help.​
              • hoaca388
                Badcaps
                • Jan 2022
                • 12441
                #268
                Serial: 5CG54674LJ
                PCID: A3009DD10303
                HP ProBook 640 G1 Notebook PC
                • SCREAM76
                  • Jan 2014
                  • 55
                  • istanbul
                  #269
                  THANKS
                  • albologna
                    • May 2022
                    • 32
                    • italy
                    #270
                    Hello.
                    Can someone help me with this ProBook 640 G1 with no display
                    Serial : 5CG5020W3M
                    Motherboard : 6050A2566302-MB-A04
                    Thank you
                    • aladin2l
                      • Sep 2020
                      • 28
                      • phillipines
                      #271
                      request bios please After i repiar this laptop with defective gain transistor on main power rail now its powering ON but the unit wont display then after second the fan slowly starting to spin very fast but no display i hope this is bios problem
                      Mainboard: 6050A2566302-MB-A03
                      Serial: MXL4110JV5
                      • peste
                        • 13924
                        • ROMANIA
                        #272
                        Serial: MXL4110JV5
                        search here, a bios according to the model of the motherboard...and try..
                        • Jayesh Fernando
                          • Sep 2024
                          • 10
                          • Srilanka
                          #273
                          Mainboard: 6050A2566302-MB-A04
                          Serial: MXL51715JV
                          Turns on No Picture Three Blink in Caps LOCK
                          Original bios is attached
                            SMDFlea commented
                            Editing a comment
                            Thread merged.
                        • hoaca388
                          Badcaps
                          • Jan 2022
                          • 12441
                          #274
                          Serial: MXL51715JV
                          • mahlcom
                            • May 2020
                            • 12
                            • algerie
                            #275
                            hi i have hp 640 g1 but have password anybody dump password m/b 6050a2566302-mb-a03
                            Serial: CNU422CNTJ
                            Product d3b09av
                            thank you​
                          • F6 Solutions
                            • Jul 2024
                            • 9
                            • Cameroon
                            #276
                            Hello
                            HP probook 640 G1 Bios corrupted
                            Sn : 5cg451274t
                            Mother board 6050A2566302 MB A04
                            thanks
                            • shiyab
                              • Sep 2023
                              • 1697
                              • india
                              #277
                              Originally posted by F6 Solutions
                              Hello
                              Sn : 5cg451274t
                              thanks
                              hi try
                              • F6 Solutions
                                • Jul 2024
                                • 9
                                • Cameroon
                                #278
                                Originally posted by shiyab
                                hi try
                                not working
                                Fan speed is higth
                                having to message at startup
                                warning: Machine is not in committed state
                                manufacturing program mode set
                                also in forum i download the files HP 640 G1 6050A2566302 MB A04
                                at startup having only message
                                Machine is not in committed state​
                                • bogdanelectronics
                                  • romania
                                  #279
                                  Hello
                                  Sn : 5CG6040QFV
                                  Mother board 6043B0141201 MB-A01
                                  Thnak you for your for your support​
                                  • LBTT1121
                                    • Nov 2024
                                    • 1240
                                    • Việt Nam
                                    #280
                                    Originally posted by bogdanelectronics
                                    Hello
                                    Sn : 5CG6040QFV
                                    hi, try and feedback
                                    • zenius
                                      by zenius
                                      12-08-2024, 06:13 AM
                                    • traxformania
                                      TONGFANG "GM7TG7P" Bios Password Problem?
                                      by traxformania
                                      I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                      But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                      I'm trying to reset my bios without success.
                                      I tried :
                                      -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                      11-15-2023, 07:32 AM
                                    • tlindi
                                      Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                      by tlindi
                                      Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                      >Read BIOS guides, methods, resources and tools
                                      Ack
                                      >Try the method at BIOS guides, methods, resources and tools before requesting help
                                      Ack
                                      >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                      python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                      01-30-2025, 04:26 AM
                                    • Soumana Sanou
                                      “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                      by Soumana Sanou
                                      Hello,😇😇😇
                                      I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                      🔧 Model: HP ProBook 11 G2
                                      📦 Serial Number: 8CG72478MY
                                      🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                      🔒 BIOS Status: Locked with password
                                      The laptop is no longer under warranty and HP refused to help me.
                                      I’m looking for a custom SMC.bin file.
                                      I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                      Thanks a lot for your help!🙏🙏🙏...
                                      06-17-2025, 04:04 PM
                                    • Nopslide
                                      HP Omen 15-dh0052nf power-on & bios password
                                      by Nopslide
                                      Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                      My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                      Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                      04-01-2024, 04:27 PM
