Hp probook 640 g1 bios
  • profiler
    • Jan 2022
    Re: HELP BIOS HP 640 G1 corrupt
    Originally posted by Vesko356
    You must post the serial number.
    Read the rules before posting:
    Sorry, here is the serial: 5CG4384S7M
    • rex98
      • Feb 2023
      • 1296
      • Mandaue CEBU, Philippines
      #242
      Originally posted by profiler
      I have exact the same problem. I tried to replace the ME Region.bin and reflash the modified outimage, but it does not change anything.
      Model: HP Probook 640 G1
      Mainboard: 6050A2566302-MB-A03
      Extracted BIOS and board images are attached.
      Thanks for help!
      Use this it works i already tested.
      • profiler
        • Jan 2022
        Hi rex98, thank you for the answer. I tried your BIOS, but the behavior keeps the same.
        • profiler
          • Jan 2022
          Re: Hp probook 640 g1 bios
          Maybe this is not a problem with the BIOS? A year ago I got this notebook and it had the problem described here. After cleaning the ME region, it suddenly works again. But after a few months it stopped working and the same problem like now appears. I had no time to fix it and leave it in this state until now. I resoldered my cable to the flash chip and readout and flashing incl. verifying works. So I tried the same procedure like that time but now I can't get it working again. Are there any other reason why caps lock is blinking 5 times followed by high speed CPU fan? I have read that this is happening when the embedded controller does not get the BIOS POST message within a certain time. So does this mean that it can't have anything to do with some power rails? The flash chip is getting 3.3V at VCC.
          • cygron
            • Oct 2017
            • 25
            • Myanmar
            #245
            HP Probook 640 G1 BIOS Need
            Board id: 6050A2566402 MB A03
            Serial: 5CG4340VDB
            PCID: A3009DD10303
            Product: D9R52AV
            Need bios. Please help.
            • szakacsa195
              • Apr 2022
              • 45
              • Magyarország
              #246
              Hi Everyone,
              My BIOS is corrupted. Laptop powers up but there is no picture.
              Could you please help and repair my attached bios dump?
              Thank you for your help!
                • 22146
                Originally posted by szakacsa195
                Hi Everyone,
                RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                https://www.badcaps.net/forum/troubl...before-posting .
                You MUST:
                • szakacsa195
                  • Apr 2022
                  • 45
                  • Magyarország
                  #248
                  You MUST:
                  Thanks for the note.
                  Model: HP ProBook 640 G1
                  Serial: 5CG43424GP
                  Board No.: 6050A2566302-MB-A03
                  Faulty Bios dump: attached
                    SMDFlea commented
                    Editing a comment
                    bios already posted at 276 ,no need to post it again
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12421
                  #249
                  Serial: 5CG43424GP
                  HP ProBook 640 G1 Notebook PC
                  • szakacsa195
                    • Apr 2022
                    • 45
                    • Magyarország
                    #250
                    Thanks for your help. Tested the new BIOS and machine turns on with display. However got the following error message:
                    What's wrong?
                    • szakacsa195
                      • Apr 2022
                      • 45
                      • Magyarország
                      #251
                      bump. Post 279
                      • hoaca388
                        Badcaps
                        • Jan 2022
                        • 12421
                        #252
                        What's wrong?
                        You just need to restore DMI. I don't have DMI for this device so I borrowed from other devices, only the serial number and product are yours.
                        • szakacsa195
                          • Apr 2022
                          • 45
                          • Magyarország
                          #253
                          With this new dump there is no picture after powering up. Problem is the same as with the original bios dump.
                          Any idea?
                          Thanks for your help!
                          • CammyTier1
                            CammyTier1 commented
                            Editing a comment
                            If your original does the same then more then likely u had a bad read or the og bios was already bad. do you get any power atall like fans spinning ect ?
                        • minhdigital
                          • Nov 2022
                          • 765
                          • Vietnam
                          #254
                          What's wrong?
                          Try Fix !!
                          • szakacsa195
                            • Apr 2022
                            • 45
                            • Magyarország
                            #255
                            Originally posted by minhdigital
                            Try Fix !!
                            Well it is much better then before, but there are still some missing information. Product family and System Board CT number are missing if I understand well.
                            Entered into BIOS and find the following informations.
                            How can I update the missing informations as well?
                            • almussafer
                              • Jun 2019
                              • 86
                              • Iraq
                              #256
                              try this and replay
                              • szakacsa195
                                • Apr 2022
                                • 45
                                • Magyarország
                                #257
                                Originally posted by almussafer
                                try this and replay
                                Now the machine powers up without error message, but every motherboard specific information are incorrect. Serial, SKU, system info, etc... How can I restore my original data?
                                • szakacsa195
                                  • Apr 2022
                                  • 45
                                  • Magyarország
                                  #258
                                  Last edited by szakacsa195; 12-15-2023, 01:53 PM. Reason: Another interesting thing: it shows Probook 650 G1 instead of 640 G1. :(
                                  • szakacsa195
                                    • Apr 2022
                                    • 45
                                    • Magyarország
                                    #259
                                    • kalilinux25
                                      • Mar 2018
                                      • 2093
                                      • ZAMBOANGA SIBUGAY
                                      #260
                                      please try this and report
                                      • zenius
                                        by zenius
                                        12-08-2024, 06:13 AM
                                      • traxformania
                                        TONGFANG "GM7TG7P" Bios Password Problem?
                                        by traxformania
                                        I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                        But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                        I'm trying to reset my bios without success.
                                        I tried :
                                        -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                        11-15-2023, 07:32 AM
                                      • tlindi
                                        Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                        by tlindi
                                        Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                        >Read BIOS guides, methods, resources and tools
                                        Ack
                                        >Try the method at BIOS guides, methods, resources and tools before requesting help
                                        Ack
                                        >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                        python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                        01-30-2025, 04:26 AM
                                      • Soumana Sanou
                                        “HP ProBook 11 G2 BIOS password reset request – Need SMC.bin
                                        by Soumana Sanou
                                        Hello,😇😇😇
                                        I need help unlocking the BIOS password on my HP ProBook 11 G2 laptop.
                                        🔧 Model: HP ProBook 11 G2
                                        📦 Serial Number: 8CG72478MY
                                        🆔 UUID: 6F5ED686-5532-11E7-A2E2-911C6404E011
                                        🔒 BIOS Status: Locked with password
                                        The laptop is no longer under warranty and HP refused to help me.
                                        I’m looking for a custom SMC.bin file.
                                        I don't have a CH341A programmer, so it's difficult for me to provide a BIOS file.
                                        Thanks a lot for your help!🙏🙏🙏...
                                        06-17-2025, 04:04 PM
                                      • Nopslide
                                        HP Omen 15-dh0052nf power-on & bios password
                                        by Nopslide
                                        Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                        My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                        Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                        04-01-2024, 04:27 PM
