asus x441sc bios request
  • Bonzas
    • 472
    • Indonesia
    Anyone have bios for this board ?
    thanks
  • peste
    • Dec 2016
    • 13451
    • ROMANIA
    Re: asus x441sc bios request
    try..
    • Bonzas
      • 472
      • Indonesia
      Thank sir, i'll tell later
      • jbonavita
        by jbonavita
        Some issues
        Things I tried
        04-29-2025, 09:38 PM
      • razor_amd
        by razor_amd
        12-15-2020, 07:07 PM
      • grimacelord
        by grimacelord
        07-10-2025, 02:52 PM
      • throwaway327
        by throwaway327
        Model No: RC72LA
        Serial No: SBNVKD001014459
        06-18-2025, 05:52 PM
      • skurvysyn
        BIOS request - Asus Rog Zephyrus GA503RS - DANJPMB3AA0 Rev. A
        by skurvysyn
        laptop had dead cpu, 3x UP9030P, audio (5v+3v+MEM short) i replaced all, now laptop turns on, vcore=1.1V, vddnb=1v, vcore_gpu=0,7v, vmem=1.1, vmem_gpu=1,2v, now to not make this a diag req. - just extra info, basically:
        original bios not available, dead bios chip, the laptop model is GA503RS, serial: N3NRCX13C597136, equipped originally with ryzen 7 6800HS, rtx 3080 - i replaced cpu, was ballsy, now there is 100-000000544 (i think its ryzen 9 6900HS/HX) - original bios behaviour=laptop turns on, cpu gpu warm, vrms continually get hotter, fan spin lower, gets faster with hotter...
        01-08-2025, 04:45 PM
