Need Panasonic FZ-G1 Bios DFUP2371ZE
  • outsider
    • Apr 2014
    • 104
    • localhost
    #61
    tuyen nguyen
    works great
    Thank You!
    • outsider
      • Apr 2014
      • 104
      • localhost
      #62
      Hello
      The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but after some time my password is no longer correct (no one else had access to the tablet at that time). Can someone explain to me what's going on and how to deal with it?​
      • cheloo73
        • Feb 2018
        • 4
        • Romania
        #63
        i need help with a locked bios on Panasonic FZ-G1.
        The uploaded dump is the original.
        Thanks!
          • 21516
          Thanks!
          Type the laptop serial number, full name and model, motherboard model, etc.
          read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
          • hoaca388
            Badcaps
            • Jan 2022
            • 12161
            #65
            Thanks!
            Unlocked
            • cheloo73
              • Feb 2018
              • 4
              • Romania
              #66
              Mainboard: DFUP2502ZC(1)
              Serial:L0890E3
              Thanks!
              • shiyab
                • Sep 2023
                • 1556
                • india
                #67
                Serial:L0890E3
                Thanks!
                post backup file and snid
                • cheloo73
                  • Feb 2018
                  • 4
                  • Romania
                  #68
                  SN:L0890E3
                  • eriko45
                    • Dec 2023
                    • 13
                    • Kenya
                    #69
                    panasonic fz g1 dfup2502zc(1) no image
                      • 21516
                      • mcsik
                        • Sep 2025
                        • Moldova
                        #71
                        Hello!
                        i need unlocked bios dump for Panasonic FZ-G1:
                        Model - FZ-G1P2122VM
                        Serial - 8ETTA20510
                        here i attached my original password bios​.
                        Thank you.
                        • volinakis
                          • Jan 2021
                          • 2819
                          • N/A
                          #72
                          Originally posted by mcsik
                          Hello!
                          Serial - 8ETTA20510
                          here i attached my original password bios.
                          Thank you.
                          try
                          • AquaMan Ua
                            by AquaMan Ua
                            05-17-2025, 09:40 AM
                          • aa10aa10
                            Panasonic Toughbook CF-33 mk1 BIOS repair
                            by aa10aa10
                            Good day,
                            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
                            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
                            01-21-2025, 06:13 AM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • Vesko356
                            by Vesko356
                            08-11-2023, 03:27 AM
                          • James Jackson
                            Panasonic CF-20G0247VM BIOS Bad Flash Help
                            by James Jackson
                            I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                            Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                            05-01-2025, 11:28 AM
