Microsoft Surface Pro 3 UEFI password
    Re: Microsoft Surface Pro 3 UEFI password
    I got a .rom file up but I can't figure out how to get the .bin file since the fptw isn't working on my platform
      The .rom and .bin extensions are just an indication of the type of file, a file with .rom extension may be exactly the same as a .bin file.
      Upload your .rom file and we’ll see.
      Did you use a BIOS chip programmer to obtain your .rom file?
      This thread is for “Surface Pro 3”, in which the password can be recovered; “Surface Book 2” is different, the UEFI variable module needs to be edited to invalidate the password.
        Yes I've seen that, if in any case someone can help decode for my Surface Book 2 would be nice, I used a software to get it something similar to fptw64
        Here's the attached file.
          No can do. Take it apart and use a programmer
            Can I use a Raspberry Pi or Arduino I don't have a programmer, any link to where I can get one also how to extract it with it?
              Yes, I almost always use raspberry pi for that.
              Just to get you started: https://www.badcaps.net/forum/showthread.php?t=43777
                This is really frustrating, it's kinda really tricky to disassemble the Surface Book 2, Is there really no way of finding the password from the rom.
                I extracted this report from the file.
                  Finding is not the problem. Deleting or decrypting is the issue here. We can find and decrypt surface 3 password because it uses a non-existent (easy to decrypt basically using a Windows calculator) encryption. Not the case with newer models. So, disassemble it is because writing is not possible with fptw.
                    Can anyone help with what my SP3 password is? I tried getting it from https://www.badcaps.net/forum/showpo...&postcount=139 but doesn't seem right to me and can't get the password to work.
                    I used ME System Tools v9.5 r6
                    fptw64 -BIOS -D SP3.bin
                      @Skroober
                      password = 3569
                        Originally posted by AAAC View Post
                        @Skroober
                        password = 3569
                        That's it, thanks!
                          Could you please provide me with a link to the decoder tool or will you only decode the firmware file?
                          Thanks in advance! Cheers!
                            Password: getmail1
                            Become a Badcaps supporter
                            Thanks to all supporters.
                              Would someone be able to help me get the password from this?
                              I tried it myself but the password I found wasn't correct.
                              Many thanks.
                                @darkfruits400
                                Password is case-sensitive:
                                password = MSSp3TaB
                                  Thank you for your help with the first one it worked for 3 out of the 4 I got from Ebay.
                                  Sorry to be a burden but could someone help me with the Bios Password for the last one as MSSp3TaB didn't work.
                                  Thank you in advance
                                    @darkfruits400
                                    The password in second BIOS.zip file is exactly the same as the one in backup.rar file... "MSSp3TaB".
                                      Hmm... that's so weird I've triple checked the capitals and entered it a few times and it's not accepting it, I redumped and attached the BIOS to be sure, but do you have any idea on what could be causing it?
                                      Thank you.
                                        @darkfruits400
                                        Same password in BiosBackup.rar file, so I suggest to use an external USB keyboard and see if that makes a difference.
                                          I've tried this with the following: SP TypeCover Keyboard / External USB Keyboard and the On screen BIOS keyboard and all are showing the password as incorrect.
                                          Any other suggestions, or will I have to take the screen off to take the CMOS battery out.
                                          Thanks.
