Asus R517s MB E402SA bios dump please
  • sopik78
    • Nov 2013
    • 520
    • Czech Republic
    Hello friends, pls share a dump of Asus R517S, mb E402SA rev 2.1.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Asus R517s MB E402SA bios dump please
    post your backup here
    • peste
      • 13924
      • ROMANIA
      try...
      • sopik78
        • Nov 2013
        • 520
        • Czech Republic
        peste: thanks, but no luck
        old dump here..
        • peste
          • 13924
          • ROMANIA
          try this one ..
          • sopik78
            • Nov 2013
            • 520
            • Czech Republic
            Thanks, but I found CPU faulty
            • Skvmik
              • Jan 2021
              • Russia
              Thanks, but my CPU is broken(
              • dihcar84
                • Aug 2012
                • 205
                • morocco
                Originally posted by skvmik
                thanks, but my cpu is broken(
                tested
                • ycok
                  • May 2017
                  • 37
                  • Türkiye
                  thanks
                  • jaazzman
                    • Jun 2021
                    • georgia
                    Originally posted by dihcar84
                    tested
                    my asus not turning on. i flashed bios dump . its working. thank you
                    • rookieme
                      • Oct 2014
                      • 403
                      • Greece
                      Originally posted by peste
                      try this one ..
                      this one doesn't work - it powers on off constantly
                      • rookieme
                        • Oct 2014
                        • 403
                        • Greece
                        tested
                        this worked but maybe some ME region cleaning is needed as it has minor delay
                        • rookieme
                          • Oct 2014
                          • 403
                          • Greece
                          try...
                          this one boots but without keyboard
                          at bios it shows platform E502SA when trying to upgrade bios
                          can somebody clean bios from post #8 so it can boot quicker?
                          • pikie
                            • Aug 2015
                            • uk
                            The way I reapired mine was the battery was dead and did not charge. With this kind of laptop if the battery is gone the laptop is basically dead given all the above faults. To resolve the matter I used an AMS117 5v voltage regulator connected it to the 19v input then ground then the output to the coil that is next to the battery. No trouble since
                            • mkdj
                              by mkdj
                              Dear all,
                              10-19-2025, 04:41 AM
                            • razor_amd
                              by razor_amd
                              12-15-2020, 07:07 PM
                            • pirati
                              by pirati
                              10-27-2025, 04:20 PM
                            • DynaxSC
                              by DynaxSC
                              06-14-2024, 03:49 PM
                            • Ahari
                              by Ahari
                              I...
                              08-13-2025, 06:12 AM
