Help with HP 830 G5 bios
  • rex98
    • Feb 2023
    • 1278
    • Mandaue CEBU, Philippines
    #221
    Originally posted by Taller Solitium
    Hi!!
    I have a 830 G5 - 5CG9060888, i change the battery, and now show password post...
    Can i help me?
    https://drive.google.com/file/d/1kp-...ew?usp=sharing
    first boot press f10 apply factory defaults and restart, 2nd boot press f10 goto security settings reset security settings to defaults.
    after that flash back your original bios main or just input manually the DMI i provided in BCU
    Serial Number: 5CG9060888
    Product #/SKU: 3JW87EA#ABE
    CT Number: PGSLT00WBBV4KR
    Description: HP EliteBook 830 G5
    BuildID: 17WWCSBT602#SABE#DABE
    Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfAhKhkjh.GF
    • Taller Solitium
      Tecnico
      • Jun 2025
      • 3
      • Spain
      #222
      Thanks you mate, but i have black screen and fan 100% with this bios :-(
      • Taller Solitium
        Tecnico
        • Jun 2025
        • 3
        • Spain
        #223
        Any can help me please?
        • lapfix
          • Mar 2020
          • 2724
          • my workshop
          #224
          Do you have a second chip...if yes post it
          Or just try this .
          First boot load bios factory defaults F10 , save and exit
          the next boot disable security options
          You must fill your DMI manually.
          • Bowayne
            • Sep 2019
            • 32
            • South Africa
            #225
            Hp Elitebook 830 G5
            ProdID 5DE84EA#ACQ
            SN# 5CG8527ZRX
            No display, on few seconds off, on few seconds off- continuously
            3V 5V 1.2V 1V present, no shorts.
            Please assist with fixing this bios issue
            • hoaca388
              Badcaps
              • Jan 2022
              • 11741
              #226
              Originally posted by Bowayne
              Hp Elitebook 830 G5
              ProdID 5DE84EA#ACQ
              SN# 5CG8527ZRX
              HP EliteBook 830 G5 Notebook PC
              • Bowayne
                • Sep 2019
                • 32
                • South Africa
                #227
                Thank you, sorry for the late response
                Unfortunately it does not switch on.
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • haitham sharabati
                  [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                  by haitham sharabati
                  Hello engineers 😀,
                  I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                  🔧 Device Info:
                  - Model: HP 15-da2007ne
                  - Product Number: 8XF55EA#ABV
                  - Serial Number: CND0338P0D
                  - CPU: Intel Celeron N4000
                  - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                  💀 Problem:😅
                  - Device shows “Administrator Password”...
                  Yesterday, 04:54 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
                • MDSI
                  HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                  by MDSI
                  I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                  Details:
                  Model : HP OMEN 17-an012nf
                  Motherboard Part Number : DAG3BAMBAF0 REV : F
                  Serial Number (S/N) : 5CD7280D51
                  BIOS chip : Winbond W25Q64VSIQ
                  Programmer : EZP2023+
                  Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                  I already...
                  07-28-2025, 07:11 AM
